Results 1 to 3 of 3
Thread: Cutting MDF
    Feb 2010
    Northern Ireland
    Cutting MDF
    I intend to cut out Names in 1 " MDF. I am using a Kress 800 but not sure of what bit to use or feed rates, plunge rate, pass depth , spindle speed etc.
    The letters will be 12" and 6" in height (joined). Any takers ?
    Mar 2003
    Shelby Twp, MI....USA
    1/4" upcut spiral, 1/4" per pass, 12,000 rpm and 150ipm.
    May 2008
    3/8 compression spiral, 0.015 chip load, 75% of that for a full depth cut (I always use 2 passes).
  1. Malaysia's Local Flame Cutting CNC, Plasma Cutting CNC Manufacturer : RobotshopCNC
    By MechanoSystems in forum Product and Manufacturer Announcements
    Last Post: 01-25-2010, 08:53 PM
  2. Newbie- Newbie needs help! cutting acrylic, and double cutting? 3040 machine
    By stephaniehamer in forum General Laser Engraving & Cutting Machine Discussion
    Last Post: 06-29-2009, 04:37 PM
  3. Can Watr jet cutting and laser cutting make endmills obsolete?
    By slashmaster in forum Benchtop Machines
    Last Post: 06-18-2009, 05:07 PM
  4. I need help about cutting heads which apply to apparel pattern cutting machine
    By sheepgrass in forum Mechanical Calculations/Engineering Design
    Last Post: 05-12-2006, 02:09 PM
