Results 1 to 7 of 7
Thread: G68 command
    Registered Ashish B's Avatar
    May 2009
    India
    Exclamation G68 command
    Hi All,
    I understand that the coordinate system is rotated.
    Refering to sketch attached it is clearly visible that the Program (executed by commanding G68) overtravels the Machine Table & can collide with the Column on which Z axis is built up.
    Than how it works & how G68 command takes care of it?
    Need Help
    Ash
    May 2007
    So if you are going to rotate the program you need to move the part on the table so it stays inside the travels.
    Registered beege's Avatar
    Feb 2008
    I believe you can rotate your program using G68 to any point on the part. You have the lower left in your drawing. You could just as easily have rotated it on the upper right corner, or the middle of the part. Then it's just a case of locating the part so no tool path goes off grid.
    BTW, it's a great way to work on a part that's longer than your X travel.
    May 2009
    India
    Exclamation Hi ALL
    In the sketch drawn I just showed you a example.
    But if we have a machine size ( 1000* 500 ) & we have to machine a part 900 * 440 & if we use G68 command (to rotate the coordinate system), then what.
    I understand that the coordinate system is rotated, but I predict that it will overtravel & all collide with the Z-axis Column.
    Ash
    May 2007
    Quote Originally Posted by Ashish B View Post
    Ash
    If you have a part that just barely fits in your machine travels then why are you rotating anything?
    The only reason to rotate the entire program would be if your 900 * 440 part were programmed with its 900 dimension along the 500 axis of the machine, or some such thing. Then you would put the part on the machine in such a way that it fits and rotate the program to match the part.
    Feb 2008
    If you use:
    G68X0Y0A5.0
    (I don't remember which "word" to use for degree of rotation, so I used A)
    your part rotates from its origin as you have drawn.
    If you use:
    G68X900.0Y440.0A5.0
    It will rotate from the upper right corner, so that the origin is lower and less left.
    If you use:
    G68X450.0Y220.0A5.0
    It should rotate about the center of the blank, upper right is now more upper, less right and lower left is more lower, less left.
    I hope I understand your query.
    May 2009
    India
    Cool Hi
    Hi
    G68 is commanded when using with probes as that avoids alignment of part. Just touch two points on the face & the whole coordinate system is rotated.
    Actually my question was that if Coordinate system rotation is commanded & suppose for eg. if the toolpath crosses the table size by 3 mm (because G68 is commanded ), then wl it show overtravel ?
    I am specfically not addressing about rotation centre ( as Beege told ), I am concern about above mentioned scenario....
    Thnks,
    Ash
    1. Problem- using the drag command
      By Claude Boudreau in forum BobCad-Cam
      Last Post: 12-07-2008, 04:12 PM
    2. M01 command
      By slideleft in forum Haas Mills
      Last Post: 11-20-2008, 04:01 PM
    3. G03 COMMAND HELP!!
      By hkfanatic in forum G-Code Programing
      Last Post: 08-04-2008, 04:14 PM
    4. Moves on command
      By IQChallenged in forum Mach Mill
      Last Post: 05-09-2008, 09:10 PM
    5. what is the same command?
      By hop in forum G-Code Programing
      Last Post: 06-20-2006, 06:24 AM
