Results 1 to 4 of 4
Thread: setting a drill &/or a c/drill on a cnc lathe
    May 2009
    south africa
    Question setting a drill &/or a c/drill on a cnc lathe
    hi guys.i'm new on a cnc lathe.i would like to know how to set-up a drill &/or a c/drill,please
    May 2009
    What kind of lathe? Does it have a tool setter?
    May 2009
    south africa
    Talking Basic setting of drill on any cnc lathe(2 axis & cnc mill/turn)
    Quote Originally Posted by mavmike View Post
    It does not have a tool setter.Sorry for not giving enough detail.It's a fanuc cnc mill/turn.Our company just bought it.It will be here tomorrow(20 Jan 2010).I never saw a cnc mill/turn in person,only in engineering books.But if you can give me advice on how to set a drill on a normal cnc mill/turn & cnc turning machine without a tool setter i will be greatful
    Nov 2005
    Alot of this depends on the specific control...drills, center drills and endmills can typically be set up the same way regardless of if they are being used as static traditional lathe tooling working on the center of the part or working as live driven tools on mill / turn machines. The major difference here being the tool holder.
    You must reference the centerline of the turret pocket to the centerline of the chuck. Once found this value should not change unless there is a crash or machine malfunction. This will be your X Geometry Offset. For end mills used to interpolate geometry on the face of a part, this becomes more complex.
    The Z Geometry offset is established by the relationship of the length of the specific tool used and the finished face of the feature being machined. This is a critical concept to understand or you will place tools into material.
    In fact, you may want to demand training on this machine / control prior to it's arrival.
    Mark T.
  1. Spade Drill Does Work in Aluminum; Big Hole Boring on Drill Press.
    By Geof in forum General Metalwork Discussion
    Last Post: 02-01-2008, 02:32 PM
  2. anyone have a Fanuc drill mate or robo drill?
    By goodplastics in forum G-Code Programing
    Last Post: 07-22-2007, 11:36 AM
  3. fanuc drill mate / robo drill post for enroute?
    By goodplastics in forum Post Processor Files
    Last Post: 07-19-2007, 06:49 PM
  4. Setting up a gang bang drill holder
    By joseavina76 in forum General Metalwork Discussion
    Last Post: 10-02-2006, 11:28 AM
  5. Can I drill AISI 1020 plate steel with a drill bit?
    By Apples in forum General Metalwork Discussion
    Last Post: 02-01-2006, 12:15 PM
