Page 1 of 2 12 LastLast
Results 1 to 12 of 16
Thread: step by step
    Oct 2009
    algria
    Unhappy step by step
    i own rover 321r with nc410 "old machine , i know"
    i need to use it usin it propre softwar, let's say only for make whole on one panel for exple: 500mm x 500mmy and thiknesse 20mm.
    so if somme one can tell me how to?
    step by step, if ther's faq any wher i wish you greats.
    nb: i whant to have exemple like that :
    1: i should create create file with name xxxxx
    2: ishoulde choise toole
    3: i should give dimention
    4: ..........
    5: ..... etc................
    pls help me
    Oct 2009
    algria
    ok
    i have made litle programe , panel with 2 holes
    on simulation evry think is ok but when i start the jobe i have message with STOP icon and it say "router config requ" do u know sommething about this message?
    Oct 2009
    algria
    all i whant is litle tuto for begining using my machine!
    is it so difficule to help me
    Nov 2008
    croatia
    I have some nice pdfs, good manuals for Biesse Rover 23, maybe can help. I was operator on one of these
    http://picasaweb.google.com/majstors...86733878259570
    How does it look on your machine? Similar to one in the picture?
    rover 23 is from year 2000, 321r is from 1994
    Oct 2009
    algria
    Quote Originally Posted by majstor76 View Post
    thank u major76 for reply
    i htink the's no mutch difference between the first and the secon, the diffrence is in the softwar part, but if u can send me the pdf manuals i wich u greats.
    this is how 321r look like:
    HTML Code:
    http://www.machinerywood.com/files/EMM002b.jpg
    Nov 2008
    croatia
    Quote Originally Posted by sarus View Post
    HTML Code:
    Im at work now so ill send you files when i got home. Can you send some pictures of software interface to see how it looks like on 321r?
    Oct 2009
    algria
    ok as soon as i take photos
    thank u
    Nov 2008
    croatia
    look for manuals in new thread
    Oct 2009
    algria
    thank u majstor76
    Nov 2008
    croatia
    thank u majstor76
    Your welcome. I had original manuals for Rover 23 but it consist of about 500 pages, 95% things average user never need. So i used posted manuals which are much better and had them by machine for quick reference. Will they be usefull to you?
    Oh, and you could try mail to biesse ask for manuals or to who ever makes controller. Maybe they have versions better for your machine.
    Feb 2008
    uk
    sarus. the 410 controller requires each tool to be specified in the tool configurations. every router bit, every drill
    have you done this?
    you either need to arrange a day of training on the machine or buy the manuals from biesse. you will really struggle without this!
    the manual has programming etc in one manual and a full book of fault codes without which you will be lost. it costs roughly £130 from biesse uk. as far as i know its not available on pdf unless anyone has copied it
    so much to learn, so much to pass on.
    Oct 2009
    algria
    battwell that write and that wase my problem, and now it's good, but i fond an other problem, the rotation sens of the slot do not turn in the write sens
    i'have looked for command witch give me the write sens but i have not fond it any where?
    utile somme one give the solution i have inverted two wire of the spindle.
  • Page 1 of 2 12 LastLast
    1. Water Cooled Spindle Step by Step
      By jeffrey001 in forum DIY CNC Router Table Machines
      Last Post: 11-26-2010, 03:05 PM
    2. Full step and half step hybrid driver?
      By rkremser in forum Stepper Motors and Drives
      Last Post: 11-20-2008, 11:22 AM
    3. Need Help!- How to edit MPFAN post file step by step
      By m_bhui in forum Post Processors for MC
      Last Post: 10-04-2008, 06:42 AM
    4. Step by step cnc plasma with parts list and links.
      By massajamesb in forum General Waterjet
      Last Post: 07-08-2007, 11:22 PM
    5. TORQUE: FULL STEP vs half step
      By Glidergider in forum Stepper Motors and Drives
      Last Post: 02-27-2007, 03:02 PM
