Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > CNC Machining Centers
CNC Machining Centers Discuss wood cutting CNC machining centers, and Point-to-Point machines here.
Old 11-12-2009, 11:12 AM
neon_x is on a distinguished road
need help rover biesse 24
hello I have a rover biesse 24 and it liked to set up some auxiliaries that exist for these you conspire and they are mounted in the cars that arise and they serve so that to put the pieces on top don't play in the suckers and when if it puts her conspires in work go down and the piece is in the suckers...
somebody gets to some pictures of those applied pieces in the it conspires... thank you...
Old 11-16-2009, 04:55 PM
foto
Old 11-30-2009, 03:25 PM
majstor76 is on a distinguished road
Didnt understand any of it...can you try in some better english? I was operator on rover 23 , maybe can help
Old 12-02-2009, 04:57 PM
thanks for your help...i need some pictures of detail of those pieces marked by me in that picturer to see as that this set up for me to set up because to 24 that I work she doesn't have
thanks...
Old 12-03-2009, 05:30 AM
Sorry , cant help you. I removed those lifters from Rover to be able to get rails closer
Old 12-04-2009, 08:37 AM
MarkT is on a distinguished road
I am not sure I fully understand, but if you are trying to retrofit a machine with the lifitng bars it is somewhat of a detailed project...several mechaincal, pnuematic and PLC additions will have to be upgraded. If you are looking for replacement lifting bars, I recommend to customers they simply reverse engineer ( measure the ones they have ) and make a program to machine replacements.
Hope this helps!
Mark T.
www.cnccustomservices.com
Old 12-05-2009, 02:22 PM
thank you for the help but I have an assembly outline but he would like to see detailed pictures to have the certainty that the assembly was correct but for this week I will put pictures here of mine conspires.
thanks to all by the help.
Need Help!- Biesse rover eng_semsem1980 Commercial CNC Wood Routers 16 12-13-2010 07:16 AM
Biesse Rover C Dogfart CNC Machining Centers 0 06-07-2009 12:17 PM
Biesse Rover 24 lostinbiesse24 Commercial CNC Wood Routers 3 05-11-2009 05:22 AM
Need Help Biesse Rover 13 Christiaan CNC Machining Centers 9 04-19-2009 05:39 PM
Biesse Rover 22 paul sharpe Teachers Hang out 2 10-09-2007 01:50 PM
