Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > CNC Machining Centers
CNC Machining Centers Discuss wood cutting CNC machining centers, and Point-to-Point machines here.
Old 11-09-2009, 05:46 AM
Ashish B's Avatar
Ashish B is on a distinguished road
Smile Spindle Orientation
HI All..
Can anyone help with PROBLEM mentioned as Under -
I command -
M19
M03 S50
M05
M00
M19
I have to command M19 two times in a program as shown above to orient Spindle 2 times consectively.
Can anyone help me that what should i command to avoid Spindle Rotation command ( M03 ) in between M19 Command to execute M19 consecutively between programs?
Ash
Old 11-09-2009, 06:21 AM
Superman's Avatar
Superman is on a distinguished road
You can't on basic machines
M19 rotates and locks the spindle in a pre-defined orientation ready for toolchange.
M5 will release the orientation, enabling you to turn the spindle by hand
M19 stated again without any manual movement will only lock the orietation in the same place ( no rotation of the spindle )
M19 stated after turning the spindle by hand will allow the spindle to orientate back to it's pre-defined spot
( this orientation setting a no play area, as fooling with values will crunch the machine when it toolchanges)
On special optioned machines
it is posible by M19 D0, M19 D180 as an example
the machine must have the options fitted and are usually found on multi-tasking milling and turning centres, mill/turns etc.
I assume you are still working on trying to gauge part features
Old 11-09-2009, 11:10 PM
Ashish B's Avatar
hI
hI
Superman
M05 command really worked for me.
Thanks a Lot
Ash
Thanks for your time support & patience
Old 11-13-2009, 05:54 AM
Ashish B's Avatar
Question Hi
Hi Superman,
If i change the orientation at 30 degree off the Spindle Orientation Position ( which is set by MTB builder ) & at the end of program if i reorient it at the Orginal Postion, do i have to caution while ATC arm is in operation.
I wanted to ask spefically that is there any hidden setting other than then the Pulse Value for orienting the Spindle ?
Ash
Old 11-13-2009, 04:03 PM
Superman's Avatar
What happens if the program is interupted, and you want to change tools ?
This is the MTB system setting area, you are fooling with the actual running of a machine function, the toolchange arm will not align with the drive keys and will eventually destroy the toolchanger altogether, maybe even the spindle tool clamp function as well
Yes, you can do it, but look at all senarios, who can do what ? can it be an accident waiting to happen, who's a$$ gets the kick if it did occur ? ( the operator is not to be held responsible for someone else's stupidity ). This is not a cheap fix and not covered under any form of warranty
I would find another method of adjusting the orientation, possibly assigning it to a M or G code that allows the M6 ( toolchange ) to cancel this orientation shift ( I don't know your machine, so I cannot help )
Old 11-13-2009, 09:12 PM
Ashish B's Avatar
Hi My Machine is Pinnacle 1100S having a Mitsubhishi control (M60). I am right now tunning the spindle orientation with G10 (Parameter INPUT) command.
Need your assitance for automatic retreving MTB Set Value before ATC Arm walks in.
Ash
Need Help!- Have no spindle orientation plofkop Okuma 8 04-05-2010 04:47 AM
Spindle orientation jrogus Haas Mills 3 08-22-2009 11:18 PM
Need Help!- Spindle Orientation JIMMY General Metal Working Machines 5 08-03-2008 12:15 PM
Spindle orientation StampCraft Haas Mills 5 11-10-2007 06:31 PM
Spindle orientation jimecv Daewoo/Doosan 4 11-09-2007 12:25 PM
