| CNC Machining Centers Discuss wood cutting CNC machining centers, and Point-to-Point machines here. |
| Hi Darek, I use the following code to probe the OD of a Boss on an Okuma with OSP5020M and OSP-E100M controllers. I have it setup as a G Code macro on G113 and works quite well. This code is for an MP10 or OMP60 Renishaw probe (on the e100) To use on the 5020M with the MP3 probe I took out the call to the probe ON/OFF routines (OO18 & OO19) Hope this helps Cheers Brian. OBOSS (*G113 CODE FOR OD GAUGING, SETTING X & Y*) (*G113 X_ Y_ H_ D_ Z_*) (*POSITION PROBE WITHIN 8MM OF BOSS CENTRE, 'Z' DISTANCE AWAY*) (*X & Y = POSITION TO ZEROSET AT*) (*H = COORDINATE SYSTEM TO ZEROSET TO*) (*D = APPROXIMATE DIAMETER OF BOSS/SPIGOT*) (*Z = Z DISTANCE FROM FACE OF BOSS - *) (* PROBE WILL TRAVEL 10MM BEYOND THIS Z DISTANCE*) VSTOH[5]=VTOFH[1] (RESET PROBE LENGTH TO ORIGINAL PROBE, TOOL 1) IF [PH EQ EMPTY] NALM1 IF [PX EQ EMPTY] NALM1 IF [PY EQ EMPTY] NALM1 IF [PD EQ EMPTY] NALM1 IF [PZ EQ EMPTY] NALM1 IF [PZ LE 0] NALM2 IF [PH LE 0] NALM1 IF [PH GT 200] NALM1 M133 (*SINGLE BLOCK VALID*) M137 (*FEEDRATE OVERRIDE VALID*) M141 (*SLIDE HOLD VALID*) G15 H=PH CALL OO18 (*TURN ON PROBE*) CALL OO10 PMOD=6 PDI=PD PZIN=PZ+10 (*GAUGE OD*) CALL OO20 PHN=PH PX=PX PY=PY (*SET ZEROSETS*) GOTO NEND3 NALM1 VUACM[1]='ERROR X,Y,H,D,Z' VDOUT[993]=4 (************) NALM2 VUACM[1]='Z MUST BE > 0' VDOUT[993]=5 (************) NEND3 G15 H=PH CALL OO19 (*TURN OFF PROBE*) RTS |
| Thanks Brian, it is important for me:CALL OO10 PMOD=6 PDI=PD PZIN=PZ+10 I use MP10 Renishaw on an Okuma VH-40 with OSP7000M controller. Do you have instructions for the milling "Gauging Manual"? (*.pdf) (for OSP7000M or OSP5020M or OSP-E100M) Could you possibly send me? darek196@o2.pl Best Regards Darek Last edited by Darek833; 10-31-2009 at 02:15 PM. |
| Hi Brian I have another question. In OSP7000M controller I can not find window "gauging results". Is there another way to display gauging results?(inner/outer diameter,distance between inner/outer faces) For example in the table "common variables".I tested the code VC1 = VS30, but controller does not accept. Darek |
| I am not absolutely certain for the OSP7000M control but on our OSP5020M control I press the "Extend" button (when in Auto Mode) until I see a function key label called "Personal". Pressing that key brings up the probe results. Hope it is the same for you. Cheers Brian. |
| Need Help!- how do you call these? | Claude Boudreau | Machine Created Art | 1 | 12-10-2008 10:18 PM |
| Need Help!- M97, M98 subroutine call. How to use | bob1112 | Haas Mills | 11 | 03-12-2008 08:41 PM |
| Heidenhain 155 >> LBL CALL | praest | General CNC (Mill and Lathe) Control Software (NC) | 3 | 09-03-2007 02:17 AM |
| What do you call it?? | Gncc50 | General CAM Discussion | 2 | 06-29-2007 02:49 PM |
| What would you call this? | MrRage | General Metal Working Machines | 7 | 09-16-2005 04:48 AM |
