Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > CNC Machining Centers
CNC Machining Centers Discuss wood cutting CNC machining centers, and Point-to-Point machines here.
Old 10-18-2009, 04:46 PM
bigz1's Avatar
bigz1 is on a distinguished road
Tooling up Biesse Rover
Hi I was wondering how to tool up a Biesse Rover 321R with the 481 controller.
I want use a different size router bit and also start using the vertical saw aggregate?
Old 11-06-2009, 05:12 AM
bigz1's Avatar
Manged to sort out the tool offsets. But am still having problem setting up the saw I tried using aggregtes table.
Would like to know what to call up when using an aggregate(TP1 or TP2 etc for routers but dont know what to use for a saw aggregate). Or should I use a fixed cycle like G7 or G9, and if so how do I incorparte them into a program?
Old 11-06-2009, 02:07 PM
MarkT is on a distinguished road
The Saw must be described properly in the tooling tables. You will not need to specify the G code if you program within the NC481 environment, it will post the proper code for you.
Email me at ntek1@aol.com and I will send you the documents showing how to structure the tooling tables.
Hope this helps!
Mark T.
www.cnccustomservices.com
Need Help!- Biesse rover eng_semsem1980 Commercial CNC Wood Routers 16 12-13-2010 07:16 AM
Biesse Rover C Dogfart CNC Machining Centers 0 06-07-2009 12:17 PM
Biesse Rover 24 lostinbiesse24 Commercial CNC Wood Routers 3 05-11-2009 05:22 AM
Need Help Biesse Rover 13 Christiaan CNC Machining Centers 9 04-19-2009 05:39 PM
Biesse Rover 22 paul sharpe Teachers Hang out 2 10-09-2007 01:50 PM
