| CNC Machining Centers Discuss wood cutting CNC machining centers, and Point-to-Point machines here. |
| Depending on the version and age of the machine, you can add "X" amount of RAM to the empty socket in the motherboard. "X" being equal to the original ram installed on the motherboard in both size and type. There are numerous techniques to square a hole, most limited by the configuration of the machine. If you have a "C" axis you can do this with an aggregate. If you have a tool changer you can program smaller diameter tools to reduce the corner radii. Note that the later technique will only get your corner to a raduis equal 1/2 of the diameter of your cutter. If the feature is hidden ( not visible or not aestetic ) you can simply over shoot the edge at least 1/2 of the cutter diameter to get a squaring effect. Hope this helps Mark T. |
| Newbie- Biesse Rover 321R CNI Compact XNC | M.B. Vanities | CNC Machining Centers | 23 | 01-19-2011 05:59 PM |
| Need Help!- Biesse rover | eng_semsem1980 | Commercial CNC Wood Routers | 16 | 12-13-2010 07:16 AM |
| Biesse , Rover 321R | lamicron | Commercial CNC Wood Routers | 9 | 11-02-2010 07:41 AM |
| Help needed Biesse 321R | M.B. Vanities | Australia, New Zealand Club house | 0 | 05-06-2009 05:30 AM |
| Biesse 321R power supply | abkdf | CNC Machining Centers | 1 | 04-20-2009 05:54 PM |
