Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > CNC Machining Centers
CNC Machining Centers Discuss wood cutting CNC machining centers, and Point-to-Point machines here.
Old 06-19-2009, 08:03 PM
Antonio Arguijo is on a distinguished road
KITAMURA MYCENTER 1/485
Hi, We have a KITAMURA Machine, Model MyCenter 1/485, we would like to add a 4th axis, the control panel have the led light for initial position for this axis, also the push button for to do it. We would like to know how to do that.
It would be possible?
Old 06-20-2009, 07:58 AM
cncmts is on a distinguished road
4Th Axis
You Have to see if the machine a servo drive for that Axis. Also alot of NC parameters will need to be set. Some depends on what kind of 4th axis you put on it.
Old 06-23-2009, 12:07 AM
KITAMURA 4TH AXIS
NOT HAVE THE DRIVE.
THE CONTROL IS FANUC 10M
WE HAVE ONE 4TH AXIS BRAND HAAS
IT WOULD BE POSSIBLE TO USE IT WITH THIS CONTROL? OR
WE MUST TO USE FANUC BRAND?
Old 06-23-2009, 04:21 AM
Yes, If you want a true-4 axis you need Fanuc Drive,Parameters, Cables. If you want to run just a 4-axis indexer "one that will only index you can't control it with a feed rate" all you need is spare "M-Code" like M100.
Old 07-02-2009, 07:07 AM
4th Axis Haas as indexer
I would like to use this 4th axis as indexer, I have M codes available, so, I need to get a drive, cables and interface board?
Old 07-02-2009, 10:30 AM
Yes
Old 07-02-2009, 09:26 PM
Could you help me to get the drive and the interface board, please?
Old 07-03-2009, 07:36 AM
4 axis
You need to see if you can find a copy of the data sheets on the machine. Then call Fanuc they will want you to fax them to them. They will be the best to tell you what parts you need. There # is 1-888-fanucus.
Old 07-27-2009, 02:50 PM
Allyd is on a distinguished road
If you want a full 4th axis then you need a servo drive and to switch on the drive requires an option parameter setting which officially has to be done by the M/C manufacturer of Fanuc. You also need the servo parameters. If it is an indexer Haas supply a control unit which you connect one of the spare M code outputs to (M42 if I remember correctly ) there is a relay and terminal on the Kitamura interface board. and an input for the Haas finished signal. Then every time the M code is output the indexer moves one program line.
Hope this helps
AllyD
Old 07-29-2009, 10:45 PM
cweiss is on a distinguished road
If you want to add the 4th as an indexer, this is not too difficult. PM me, and I will discuss with you the process. As a full 4th, it is as the others stated here.
Learn more at Bostock CNC online
http://www.bostock-cnc.com/
  #11   Ban this user!
Old 09-26-2010, 03:51 AM
Balaji Naragude is on a distinguished road
Hi
I have purchased Kitamura Mycenter 1/485 (used) recently. Control is Fanuc 10M. But when i started machine there no parameters in system. Can you help me by providing Parameter List?
  #12   Ban this user!
Old 06-08-2011, 11:09 AM
abmts is on a distinguished road
Is there anybody out there that can help with a parameter list for a Kitamura Mycenter 1/485 Machining center with Fanuc OMC control?
Kitamura Mycenter 3B parameters omarandujo Excitech routers 0 01-22-2009 11:45 AM
Kitamura Mycenter cdlenterprises General Metal Working Machines 2 11-19-2007 11:25 PM
Kitamura Mycenter 3B sebaja General Metal Working Machines 0 10-16-2007 06:22 PM
kITAMURA MYCENTER-1 Help needed again!! aghobby Fanuc 5 07-11-2007 03:53 AM
Kitamura Mycenter 0 inertialabs Shopmaster/Shoptask 0 01-15-2007 09:47 PM
