Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > CNC Machining Centers
CNC Machining Centers Discuss wood cutting CNC machining centers, and Point-to-Point machines here.
Old 06-09-2009, 05:58 PM
bri008 is on a distinguished road
Creating Sub Program In Genises
Can someone help me, I need to know how to create a sub program using genises software on a busellato Jet 130 machine.
Hope somone can help.
Cheers
Old 07-24-2009, 07:44 AM
rsimmons is on a distinguished road
Just create a program like normal but save it as a three digit number from 000 to 999. It must be saved in the "SUB" folder inside of the "product" folder. Subprograms are a life saver for us and make automation a breeze! We have a JET4002XL that runs Genesis and a JET200RT that runs Evolution. Let me know if you need any more help. I have a lot of experience with these machines and software.
R
Old 07-24-2009, 02:06 PM
Setting Rouring dept on Jet130
Thanks for the info, Can you help in that when I import a dxg/dwg into cnc editor,it defaults to setting all depths to zero. How and what would be the quickest way to set all lines to a specific depth. Instead doing it individually,tried find/replace function, but keep on having to click find next.
Also is there a manual for the genises software that explains in detail, all the programming techniques.
Hope you can help,
Thanks,
Brian.
Old 07-27-2009, 07:54 AM
bri,
You have to give specific layer names (in AutoCAD) to specific operations. You control the depth, tool, feed rate, etc. all by the layer name. If you go to autocutresearch.com go to the downloads or FTP page look for the AutoLink Manual. This will tell you all about the layer naming convention.
As for the Manual for the genesis software, I have a big "telephone book" manual but all it is is the help file in print. So just check that out. If for some reason you don't have the help file, I can upload it to for you. It is hard to read thought. Is a horrible translation from Italian.
Old 07-27-2009, 06:55 PM
Cheers for the manual, will have a read through this. The autolink looks good, working in cad, do you know what the cost is or where you get activation code?
Old 07-28-2009, 07:11 AM
Contact Bill Blackmon at Delmac. He can help you out.
Office: 336.854.1211 x321
Cell: 336.707.2465
email: bblackmon@delmac.com
Old 09-07-2009, 02:26 PM
menuisier is on a distinguished road
Hi there thank you for the offre , I also run genesis software in our jet 3000 busellato. but I found a wee porblem and I need your help, would you please walk me through if you would. ok my problem is tool parametre and outfit parametres coming with an error (e11)invalid tool . but drilling works fine thanks for your help . menuiser
Old 09-08-2009, 06:58 AM
menuisier,
First of all are you using Genesis or Genesis Evolution? What is the version number? When are you getting this error? Are you getting it when you are setting up a tool? Or when you try to run a program? Please give more detail.
Ryan
help creating program brockadeau Mechanical Calculations/Engineering Design 1 11-16-2007 09:01 PM
Creating .dxf files lal19541 General CAM Discussion 4 08-31-2006 02:40 AM
creating a surface corrie BobCad-Cam 7 03-21-2006 06:02 PM
Creating a PCB? GunnySnow General Electronics Discussion 1 06-14-2004 11:11 PM
creating surface Mortek OneCNC 5 05-20-2003 11:11 AM
