Results 1 to 7 of 7
Thread: what is it?
    Registered ToyMaker's Avatar
    May 2003
    Question what is it?
    OK let's see just how ignorant I am.
    What the heck is a point-to-point machine and how does it contrast to an other than p2p machine?
    robotic regards,
    Tom
    Site Owner CNCadmin's Avatar
    Mar 2003
    here is what they look like http://www.huester.co.za/wood_cnc_alberti1.html
    http://www.biesseusa.com/biesseusa/p...se/rover24.htm
    A PtoP machine is a machine with pods or stations that allow pre-cut pieces of wood to be place on one side of the machine. And allows another piece to be place on the other side. So the machine is continually maching parts. The machine uses Pods that suck down the board and hold it while it gets machined.
    Thank You,
    Paul G
    Site Owner-Webmaster-
    Administrator
    www.rfqwork.com
    www.cnczone.com
    www.welderzone.com
    Mar 2003
    I changed the name this one is a better well known name for these type of machines.
    Thank You,
    Paul G
    Administrator
    www.rfqwork.com
    www.cnczone.com
    www.welderzone.com
    May 2003
    Thanks for the info Paul.
    There's so much to learn and so little time !
    robotic regards,
    Tom
    May 2003
    The Pennines, England
    Hmm.... I think I'd prefer to describe it this. A PtoP CNC router is the offspring of a PtoP drilling machine - a multi-headed CNC drilling machine designed to drill cabinet sides (32mm system) quickly. I think the point-to-point monniker came about because the drilling points are described as X/Y co-ordinate and depth of hole and the machine moved from "point to point" to drill dowel holes, screw holes, hinge pockets. Later machine makers started to add one then more router spindles and saw heads in order that the machines could profile edges of stock and saw grooves for cabinet backs.
    Just my two pennorth
    Scrit
    from the Sunny Pennines, England's Backbone
    Mar 2003
    Shelby Twp, MI....USA
    The machine we have (Masterwood 327) has 21 vertical spindles, 6 horizontal spindles, a grooving saw and 2 9HP Router spindles, one with a 5 position tool changer. This versus a cnc router, which usually has, a router.
    May 2003
    I run the same sort of thing. Biesse Rover 335 - 24 vertical/8 horizontal spindles and three router spindles.
    Scrit
  • Posting Permissions
