Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > CNC Machining Centers
CNC Machining Centers Discuss wood cutting CNC machining centers, and Point-to-Point machines here.
Old 05-05-2009, 12:57 AM
Bada Bing is on a distinguished road
Post Komo VR-408 CNC Router
Does anyone know how to stop the X-axis servo motor from groaning while sitting idle on a Komo VR-408 CNC Router?
Old 05-09-2009, 08:10 AM
CNCRouterMan is on a distinguished road
Turn machine on. Home it. Loosen the bolts on the gantry. Move back and forth at a slow speed a couple of times and tighten up bolts. The groaning or humming is caused by the servo's fighting each other.
Old 05-15-2009, 12:22 AM
I am not sure which bolts the gantry bolts are?
Old 05-15-2009, 09:26 AM
One of Many is on a distinguished road
A Komo VR-408 is a stationary gantry, X axis moving table Router. There are no servos fighting each other. The gantry is welded to the base frame. If it has absolute encoders, there is no homing procedure either...
Mechanically, there could be excessive drag on the linear rail trucks, ball screw issues, ball screw support bearings or motor/ballscrew coupling.
It may have Fanuc AC servos. I'd also suspect a lag between the motor coupling and the encoder, Hum is often the feedback/servo system hunting with overshoot due to external forces resisting it coming to rest. Or not knowing it should be at rest, the tuning has deviated from null at idle.
You may only be able to take care of the obvious, but a field tech could have it cured before it stresses the electronics into failure as it generates heat into all in the loop.
DC
Learn cause and effect through experience. Mastering those relationships is the "Common Sense" ability within the art of any trade.
Old 06-18-2009, 02:44 PM
dadelmann is on a distinguished road
You say it hums at idle; does that mean at any X position or only at the home position? For example if you let it idle when X is at its center of travel will it hum?
Old 06-20-2009, 11:33 PM
yes it humms at any -X- position.
Old 01-22-2011, 09:53 PM
CNC_Monkey is on a distinguished road
Did you call tech support?
KOMO's have a free lifetime 24/7 tech support line.
Old 01-27-2011, 05:02 PM
techdir is on a distinguished road
have you looked at the servo brake circut? I have a vr1008 twin table that does the same! try a power conditioner in the braking circut!
KOMO MACH III (2006) Zach Silkett Commercial CNC Wood Routers 0 03-12-2009 02:15 PM
KOMO Extreme routerhead805 WoodWorking 0 02-10-2009 07:18 PM
Need Help!- Alphacam post for Komo 3 axis router man Post Processor Files 0 05-13-2008 09:27 AM
Komo Mach 1 error Atom13 Commercial CNC Wood Routers 0 09-26-2007 05:47 PM
Need help with: Komo VR 512 CNC Router Nickk6 Commercial CNC Wood Routers 2 05-01-2006 01:59 PM
