Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > CNC Machining Centers
CNC Machining Centers Discuss wood cutting CNC machining centers, and Point-to-Point machines here.
Old 04-10-2009, 09:57 AM
Christiaan is on a distinguished road
Need Help Biesse Rover 13
Hello,
I`m a newbie in the world of cnc. I bought a used Biesse Rover 13 from 1996, removed the transport clampingbrackets (just 2 instead of 3 the manual shows) installed the machine but when I turn it on, the display show: ALARM - err 3 Machine in Emergency. The Z-axis isn`t moving and still laying on the workingtable.
What do I have to do, or better how do I get the machine starting?
Best regards
Alex
Old 04-10-2009, 05:51 PM
majstor76 is on a distinguished road
I work on rover 23 from 1999...Can you start calibration process? Pressure is connected and valve open? Im shooting in the dark here, dont know how similar machines are
Old 04-11-2009, 02:21 AM
battwell is on a distinguished road
is air supply at 100psi?
air leaks ie hiss anywhere?
can you make global reset on controller?
do you have operation manual?
Old 04-11-2009, 07:14 AM
MarkT is on a distinguished road
Machine in Emergency references you should troubleshoot your 24v DC emergency electrical circuit. Could be just a breaker, contactor, thermal overlaod, wire, etc. You have to get the green start light to be able to move the machine, this circuit enables the green start light. Next, your router on the table, if the "Z" axis is on a limit switch you will have to get it off the switch in order to reference / home the machine.
Hope this Helps
Mark T.
www.cnccustomservices.com
Old 04-13-2009, 01:16 AM
Hello majstor76,
When I turn the mainswitch on, I push te green startbutton, then press stop, then reset, then clear. At that time there is`nt any failure on the screen.The vacuumpump starts running, the calibrationproces begins, but the router still stays down on the beams, it won`t come up. After several seconds the screen shows again: err 3 and alarm.
Regards
Alex
Old 04-13-2009, 03:52 AM
@Markt and batwell,
Could it be the problem that I have not enough power/amps on my electric system in the workshop, it`s an 380/400volt system with 3 fases, 16amps fuse and I discovered that one of the fuses is breaking down when the machine is starting callibrating.
Old 04-13-2009, 03:57 AM
Do you have manual? There should be electrical REQ of the machine
Old 04-13-2009, 05:44 AM
First rule out if the "Z" axis is on it's limit switch. The switchs look like a small wheels ( either 2 or 3) sticking out of a little box. As the axis moves up or down, the approriate switch (wheel) will ride up a small ramp. If any of your wheels are setting on a down ramp, the machine will not home until you get it off the ramp.
The auto transofromer on the machine should accomondate any 3 phase voltage from 200-600 volts. Amps is another issue. I will be working on a Rover20 this week so i can confirm, however I am relatively sure that machine needs to be on a 30-40 amp service. Maybe more.
Hope this helps!
Mark T.
Old 04-14-2009, 01:19 PM
my 321 runs on a 32amp outlet.
230volt 3 phase in uk.
like mark says double check your z axis hasnt gone onto limit switch if in doubt you can turn motor by hand with the machine powered off.
also check you have no air leaks before powering up. my 321 has a pneumatic z axis park which sometimes sticks if the control solenoid doesnt quite shut off. this is best checked with the vacuum pump switched off so you can hear the hiss.
if you go to manual movement can you jog the x y and z axis around?
if not press the overide axis button and try again, should let you jog off limit switch. you need the machine switched on and vac pump running to do this
Old 04-19-2009, 04:39 PM
CNC TECH is on a distinguished road
The Z axis has a mechanical brake, if your machine was standing for sometime these have a tendency to stick which would cause your drive for the Zaxis to show an alarm for "over current" maybe explaining your alarm message. Normaly a sharp tug (anticlockwise) with an Hex key in one of the bolts of the pulley for the motor is enough to free it.
Your power supply is not enough for this machine either 32amp 3ph is border line 45amp 3ph is more preferable, hope this helps
Need Help!- Biesse rover eng_semsem1980 Commercial CNC Wood Routers 16 12-13-2010 06:16 AM
microvellum for a biesse rover 4.4 robbie prime CNC Machining Centers 2 07-06-2009 11:19 PM
Biesse Rover 24 lostinbiesse24 Commercial CNC Wood Routers 3 05-11-2009 04:22 AM
Need Help!- Biesse Rover 22 help required escape CNC Machining Centers 0 02-27-2008 07:40 AM
Biesse Rover 22 paul sharpe Teachers Hang out 2 10-09-2007 12:50 PM
