Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > CNC Machining Centers
CNC Machining Centers Discuss wood cutting CNC machining centers, and Point-to-Point machines here.
Old 02-08-2009, 09:19 AM
DANMI38 is on a distinguished road
Thumbs up I lost parameter rover 322
I need help .. I lost my machine parameters BIESSE Rover 322 I would like to know if you are selling
could give me a copy or sell the parameters thanks for your help
Old 02-10-2009, 02:22 PM
battwell is on a distinguished road
do you mean you lost boot up disk?
Old 02-11-2009, 10:50 AM
The machine is blocked for lack of the correct parameters .. because deleted by mistake .. the machine model is BIESSE ROVER 322 YEAR 1997
Old 02-13-2009, 01:50 AM
Jeroen aalders is on a distinguished road
most of the time they keep a floppy or a list of parameter in the eletrical kabinet of the machine. if so your lucky
otherwise you need to find anothermacine that is the seem and copy the parameter from it. or ask the manufacturer for the parameters you need. most of the time the are so kindly to give you them to you.
best luck,
Jeroen
Old 06-30-2010, 03:49 PM
mar404 is on a distinguished road
I lost parameter rover 316
could anyone help?
Old 06-30-2010, 05:03 PM
lost because deleted or memory battery flat? (lead acid 4v bolted to side of controller inside frame. looks like a bomb!)
what controller number? 480? 481?
so much to learn, so much to pass on.
Need Help!- Biesse rover eng_semsem1980 Commercial CNC Wood Routers 16 12-13-2010 06:16 AM
Need Help!- VMC - SUPERMAX 60A parameter lost rajesh_1355 Fanuc 6 11-08-2008 12:31 PM
Fanuc 0M-C ---Parameter lost rajappa Fanuc 3 06-12-2008 06:25 PM
Hitashi Seiki VM40 MIII the parameter are lost igttech CNCzone Club House 0 03-11-2008 08:41 AM
Bieese rover 342 eng_semsem1980 Xylotex 0 07-10-2007 04:22 AM
