| CNC Machining Centers Discuss wood cutting CNC machining centers, and Point-to-Point machines here. |
| double vices? No, regular milling vice, yes. Import vices aren't always very flat, the rear jaw tends to flex when you clamp on a part and the floating jaw floats way too much, sometimes making it difficult to hold a part super flat for precision machining. If your doing .005" tolerances or less, buy american for sure, if you need matched vices, buy american for sure. |
| I've got a couple of different cheap import double vises. I wish I had bought two of the same model at one go, because the width of the fixed center jaw is different, as well as the jaw plates themselves being different profile and hole spacing between the two vises. The workmanship is not great: eccentric screw heads (Chinese allen caps suck bad) in too small counterbores = jaw plates that swim around and do not necessarily sit on the vise bed. The vises I have did have a sort of angle-lock principle in the sliding jaws. Seemed to work well enough with a bit of polishing up and an application of grease to the swivel. So you might save some money buying the cheap import, then turn and spend some time making them right. BTW, the bolt pattern in the jaws is typically much different than Kurt, so you cannot swap jaws with your Kurt vises.
| I bought a 4 and 6" double off ebay for $600 for the pair. I know it was a STEAL but the deals are out there. Check the auctions! At the auctions (online) I picked up 3 Kurt vises for $99 ea and one needed a little work but still a heck of a deal! i remember literally breaking a chinese vise in half trying to get good grip on a part
__________________ We have had good luck with our Fadals milling mostly soft steel and aluminum up to 5 axis. We are always looking for spare parts If you have a broken down Fadal give a shout. |
Tell me about it, the only thing worse than six is twelve .But worth every penny in the long run; don't cheap-out get the best with a name beginning with K.
| beware Taiwan How-Mau Machinery Co., Ltd. | JackOz | Vendor Discussion | 2 | 09-07-2010 02:18 PM |
| TAIWAN HOW-MAU MACHINERY CNC K3 | kanton | Benchtop Machines | 8 | 01-19-2010 07:25 PM |
| programming multiple double vises | bink | G-Code Programing | 12 | 10-26-2006 09:07 PM |
| Taiwan/China Tooling | Zumba | General Metalwork Discussion | 8 | 03-27-2006 01:56 PM |
| CNC Parts Bargins in Taiwan? | Mr.Chips | DIY-CNC Router Table Machines | 24 | 11-24-2004 04:59 PM |
