Page 1 of 2 12 LastLast
Results 1 to 12 of 23
Thread: Morbidelli Author 504K RS232 settings
    Jan 2009
    MX
    Question Morbidelli Author 504K RS232 settings
    Hi people.
    I have 2 machines:
    1; Morbidelli Author 504k
    Control Tria 7500
    2; Morbidelli Author 504
    Control Tria 7500
    Normally we load the programs via floppies, we want to use the serial port of the controller, but we don't have the manual, I have googling but I have not found the info.
    Some could help me with this info? I will build the cable what is the configuration? Someone have the manual for this machines?
    Last thing, how to setup the connection?(Parity, Stop Bit, etc, etc.)
    Thanks all for your time, hope someone could show me some light, I will apprecited, thanks again for your time!!!
    Sep 2008
    Quote Originally Posted by klabacita View Post
    Hi people.
    I have 2 machines:
    Control Tria 7500
    Control Tria 7500
    Do you still need information?
    I have Morbideli A502 & U550 I have also been using only floppies but I plan to use serial cable and Kermit. I have information available but not the experience at this stage. I am happy to supply the documentation I have.
    Jul 2009
    Ireland
    I have a morbidelli 504 with a Tria 7500 controller battery has gone need info on getting it going again?
    Jul 2009
    Ireland
    Thumbs up morbidelli Author 504
    I have a morbidelli A504 with a Tria 7500 controller and side tool changer. Battery has gone dead, need info on getting it going again or where I can get help?
    Thanks.
    May 2009
    Tria Connections
    Quote Originally Posted by beeonline View Post
    Try this connection. See Attached
    Attached Thumbnails Attached Thumbnails Morbidelli  Author 504K RS232 settings-tria_connections.jpg
    Sep 2009
    Germany
    Question
    Hello Morbidelli 504 Guys,
    I've owned a '94 504 for a while now and just had to replace the Inverter with a new one made by Fuji.The problem I'm having is that we wired in the Inverter tonight and the Programm stops with the Spindle running with the Z Axis in upper position.I assume there is a signal not being sent to the controls, that the correct RPM has been reached.We let the spindle run at roughly 5000 RPM.Could this have an Impact on the Progamm being interrupted? I unfortunatelly haven't seen the spindle run untill today on this machine, so I have no referance.Would I possably have to reduce the RPM that the Spindle was set at to make this work? I would really apreciate any respond to the Problem I am experiencing. Thank you!
    Jul 2009
    Ireland
    hi all,
    I got sorted with my morbidelli A504 got floppy disc from scm in england who were a great help. Thanks for all the help from ye.
    May 2010
    Bulgaria
    Hello, I have been setting a RS232 connecttion to old Morbidelli AUTHOR 1500 using the Windows built-in HyperTerminal and the cable connection mentioned by CNCRouterMan(three wires)
    Bits per second 9600
    Data bits:8
    Parity: None
    Stop bits: 1
    Flow Control: None
    I would suggest lower transfer rate if cable is unshielded or/and longer than 5meters.
    I have managed to transmit files from the machine to PC with no problem using this setup BUT there is some weired "bug" when trying to transmit from PC to the machine: I have to set the machine to get the file named XXXX.PGM and wait about a minute before send the file from HyperTerminal, otherwise I get message saying "illegal message format" or transfer cancelled by the other side.
    If you know how to resolve this issue please let me know, THANK YOU
    Apr 2006
    CROATIA
    I have Morbidelli with Tria 6000 control, how can I transfer program file from my PC to CNC?
    Dec 2010
    indonesia
    Hello all guys, I'm beginner using the morbidelli tria 7500. this is second hand machine just finished install all the electricity. I cannot going forward operate this machine because on the monitor said: "plc block, error 000"
    would you please give me information what should I do? many thanks for the respond.
    May 2009
    reply to rofiksumartopo
    rofiksumartopo It sounds like you lost your plc perameters because of battery back up dead. Replace the battery and call SCM about sending you the plc perameters file and steps to load back into system.
    Jun 2010
    Argentina
    Have resolved the inverter problem ?
  • Page 1 of 2 12 LastLast
    1. Tria 7500 for Morbidelli Author 503
      By stoned in forum General CNC (Mill and Lathe) Control Software (NC)
      Last Post: 10-20-2012, 10:36 AM
    2. RS232 Settings for CNC Arrow 750
      By SSWELD in forum General CNC (Mill and Lathe) Control Software (NC)
      Last Post: 08-27-2010, 02:46 PM
    3. Morbidelli Vs Masterwood for solid wood machining
      By thinkingcnc in forum CNC Machining Centers
      Last Post: 12-29-2008, 11:13 AM
    4. OKUMA OSP-U10L RS232 SETTINGS
      By edmondyjh in forum Okuma
      Last Post: 09-25-2008, 03:13 PM
    5. morbidelli MAGNETIC dc servo
      By michaeldriscoll in forum Servo Motors and Drives
      Last Post: 01-05-2008, 03:28 PM
