Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > CNC Machining Centers
CNC Machining Centers Discuss wood cutting CNC machining centers, and Point-to-Point machines here.
  #13   Ban this user!
Old 01-10-2007, 11:24 AM
mtd091571 is on a distinguished road
Kress and USA power
Can anyone tell me what I would need to do, to power a kress on my 110v in the usa? I've looked for foreign power converters, but the only one's I can get my hands on convert the wrong way. US to Euro. Plus I really don't know what the heck I'm looking at. I would greatly appreciate any help or a point in the right direction. I really want to get one and try it out. Thanks!
  #14   Ban this user!
Old 01-10-2007, 06:50 PM
SteveS's Avatar
SteveS is on a distinguished road
Kress at 110 volt
My Kress motors came as 110 volt. I have two pictures of mine in the gallery, one shows part of the 110 sticker.
http://www.cnczone.com/gallery/data/..._Collector.JPG
Do you have a 220 volt Kress already??
See this link;
http://www.kress-elektrik.de/en/prod...?categorie=767
Seems they changed their models from mine.
  #15   Ban this user!
Old 01-10-2007, 07:31 PM
I don't have one as of yet. I just received a email from Techno Isel saying they have a 110v version of the 800W for around $280. Seems kind of high when I see this link on ebay for $162
http://cgi.ebay.com/ws/eBayISAPI.dll...m=280062047868
The only thing is it states this...
2,5 m mains cable with Euro 2 pin plug
I don't even know what that means heehee...
Is that a debece router that you have? Looks nice from what I can see.
Old 01-26-2007, 09:04 AM
*Registered User*
marchantdice is on a distinguished road
[QUOTE=mtd091571;240677]I don't have one as of yet. I just received a email from Techno Isel saying they have a 110v version of the 800W for around $280. Seems kind of high when I see this link on ebay for $162
A Euro 2 pin plug is similar to your plug: home use, however this does not matter as you can remove this plug and replace it with your own as the motor does not require an earth connection. Regards / Marchantdice
  #17   Ban this user!
Old 01-26-2007, 09:55 AM
braidmeister's Avatar
braidmeister is an unknown quantity at this point
Steve,
It might be worth your while to replace the control with Mach3 & an appropriate breakout board. A 3-axis machine running steppers...is a 3 axis machine running steppers. Nothing special about the machine you bought. If the steppers are mis-matched, I am sure that you can replace them as well with any number of steppers out there, like the Tormach Nema 23 ones.
If you ran Mach3, you could buy any number of breakout boards, such as the ones offered by Bob Campbell, and wire up the step & direction signals off of the Nanotec drivers to the breakout board. There's not a whole lot more to it than that...then you'll have your choice of any number of cad/cam programs out there with a Mach3 post processor available for just about everything...Anyway, that's what I would do. The machine hardware doesn't make much difference. 3 axis is 3 axis.
-Brady
  #18   Ban this user!
Old 05-15-2008, 06:22 PM
david forward is on a distinguished road
Hello everybody, I'm thinking of buying a larken cnc 5x10 2001 model with 10 h spindle for building kitchen cabs and mdf doors , any thoughts?
  #19   Ban this user!
Old 02-07-2009, 08:11 AM
Jetleg-Jazzman is on a distinguished road
Originally Posted by SteveS View Post
I started this thread. I bought a Debece router DTR200S which had several options and came with the Kress routing motor off of E-Bay. Original owner ended up changing jobs and couldn't pursue it.
Hi Steve... I also have just purchased what I believe is a Debece from a seller on eBay. It have three diffrent size motors just as you have described and a Kress router. The machine is in beautiful like new condition. It came with WinPC-NC software but no instructions. Most information I have found is German. Is the instructions you have in a PDF? If so could you be so kind to send me a copy? I have some images in Corel that I'd like to start testing with but I have no idea how to get the drawings from one program to the other. Any help or insight would be greatly appreciated.
  #20   Ban this user!
Old 02-07-2009, 08:59 AM
SteveS's Avatar
Debece Info
Attached is email that I recieved back from the software author in 2005.
Dear Mr. Stram,
many thanks for your mail and for using our software.
Please find the new software in attachment. Do not forget to update the firmware in the axis controller as well.
Please feel free to contact us again.
Best regards
B.Lewetz
Burkhard Lewetz
Hard-Software
Brueckenstrasse 7
D-88074 Meckenbeuren
Tel. ++49-7542-21886
Fax ++49-7542-3889
eMail info@lewetz.de
Homepage www.lewetz.de
Am 24 Jul 2005, um 10:03 hat Steve geschrieben:
The files he sent me are attached to this post.
You will set the distance per pulse through the controller software. It took me a couple of times to get that right.
I would suggest you get use to working in metric, as the english units don't always seem to translate right.
Being my machine uses a serial interface, I am planning to change over to a new controller that will interface with Mach3 CAM. Most likely the Hobby CNC kit.
Only in the past 2 months (since 2005) have I been able to concentrate on the machine for continuous periods of time. My use to date is almost entirely 2-D cutting of wood. I create the model in Bob-CAD and use the CAM feature to generate the g-code. Bob-CAD made a post processor for the Win-PCNC software interface. I didn't put much effort into the HPGL or PLT file method, but would be interested in any success you have.
File Type: txt Attachment information 2.txt‎ (836 Bytes, 37 views)
File Type: txt Attachment information..txt‎ (842 Bytes, 60 views)
  #21   Ban this user!
Old 02-07-2009, 09:40 AM
Hi Steve... thank you for the quick response... and a BIG thank you for the instruction manual! most of my measurments are already in metric so i think I will jet resolve myself to using that system. Thanks for the tip!
My machine also has a serial port interface so if you change over please keep me posted on your results.
I just got the machine yesterday and hope to make some progress over the weekend. I plan to use the machine to make solid body guitars and custom neck inlays. So the 3rd Z axes will be a necessary step for me.
Do you think it would be possible to use another (3d) software? I mean all this gets translated to coordinates and plunge depths anyway right?
This is all part of the controller? and it interfaces the machine with the software? This may seem like a silly questions but what does it look like? where on my machine can I find it? If I wanted to use a different software would I have to change it?
I was able to find some DFX and DWG files already complete of standard guitar body shapes. Is their any way I can import or use these files with the WinPC-NC software that you know of?
I know this is a lot and I'll likely have to learn the hard way thanks so much for your help.
  #22   Ban this user!
Old 02-11-2009, 08:24 AM
Anyone using Mach3 for Debece?
Okay I got a deal on a Debece that came with WinPC-NC however I have not had any luck.
WinPC-NC software to me sounds a lot like Mach3 as they each clam to turn your PC into a controller. Not that I know anything about Mach3 but they do have a lot more support and larger community.
Has anyone used Mach3 on their Debece CNC? Will it work? Would I have to make any other modifications?
  #23   Ban this user!
Old 02-11-2009, 11:34 AM
SteveS's Avatar
The WINPC-NC is very popular in Europe, expecially Germany. It seems they use HPGL files quite often. Essentially with HPGL the CNC works like the old school gantry pen plotters. HPGL seems to only use pen-up and pen-down, so any real 3D is beyond me.
Biggest issues with Debece and WINPC-NC are the serial cable connection and the dedicated controller with firmware. You either need to learn the system in place or replace all or it to the stepper motors. The learning curve was not pretty for me, but I had the time.
I am creating g-code through BCC. The ISO g-code set needs to be very limited and it took some time for me to figure out how to avoid crop circles. Using another software that may not be a problem.
If you can afford it, I would reccomend you buying a complete system of opto isolator, breakout board and motor controllers. I will be doing this in the next 90 days. This can be as cheap as under $100 in kit form from Hobby CNC if you feel confident in soldering. Otherwise there are quite a few turnkey systems. That way you can use any of the common CAM programs like as DeskNC, TurboCNC, Machx directly.
I have no complaints about the Debece machine mechanically and the Kress router is world class. I see on-line that the newer ones from Germany have two x-axis stepper motors instead of the belt driven opposite side. Mine came with the dust collector and limit switches.
  #24   Ban this user!
Old 02-14-2009, 07:55 AM
itsgreg is on a distinguished road
I also have a similar machine that also uses the kress routing motor FM 6990. We can no longer get this motor and was needing to know of another supplier or a good replacemnt for it.
Techno-Isel CNC router for sale? Noah Commercial CNC Wood Routers 5 11-27-2008 10:12 PM
2nd Generation CNC Router Design 32.5” X 14” X 6” gregmary DIY-CNC Router Table Machines 9 03-24-2005 04:46 PM
CNC Router Taper Machine hadjcues DIY-CNC Router Table Machines 8 03-23-2005 05:02 PM
buscht's cnc router buscht DIY-CNC Router Table Machines 25 04-13-2004 11:43 AM
My first CNC router: 1.5 years building hddjohns DIY-CNC Router Table Machines 2 04-03-2004 10:18 AM
