Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > CNC Machining Centers
CNC Machining Centers Discuss wood cutting CNC machining centers, and Point-to-Point machines here.
Old 10-10-2008, 10:10 AM
vivagolf is on a distinguished road
Feed rate and rpm's
Can anyone help?
We are new, new new to using a CNC machine.
We are in the process of trying to cut 1/2" OSB board and cannot get the feed rate and spindle rpm's down. We have already broken 5 bits. Can anyone give us some good starting point on the feed rate and rpms we should use?
Larry
Old 10-10-2008, 10:15 AM
ger21's Avatar
What size bits? It's very difficult to break a bit unless your rpm and feedrates are way off, unless your using 1/8" or smaller bits.
What is your tool size and type? Feedrate? RPM? Depth of cut?
Old 10-10-2008, 10:20 AM
We were using a 1/4" bit. and were trying different rpms and feed rates. We at first tried to cut through on one cut but then went to 1/2 trying different speeds then just gave up.
Old 10-10-2008, 10:28 AM
ger21's Avatar
Try full depth at 17,000 rpm and 150ipm. I'm assuming you're using a solid carbide spiral bit? Carbide tipped 1/4" bits aren't nearly strong enough to hold up for long.
Old 10-10-2008, 12:41 PM
Thanks Gerry will try it.
Need Help!- Feed rate for 5/8-18 tap Eagle View General Metalwork Discussion 2 09-24-2008 09:25 AM
Need Help!- Feed rate Ovverride also Increases rapid rate. Korellibopper Machines running Mach Software 1 01-30-2008 05:37 PM
Feed Rate and Spindle Rate for this cut? DroopyPawn General Metalwork Discussion 20 11-21-2007 11:12 PM
Feed Rate? bearwen GRZ Software- MeshCAM 3 04-26-2006 04:52 PM
How can I up my feed rate ? ynneb DIY-CNC Router Table Machines 7 07-12-2004 09:40 PM
