Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > CNC Machining Centers
CNC Machining Centers Discuss wood cutting CNC machining centers, and Point-to-Point machines here.
Old 09-05-2008, 05:52 PM
obieron is on a distinguished road
Parameter Settings for Toyoda Lathe (FANUC 11T)
Parameters wipped out! No backup! Starting from scratch. Anyone have a Toyoda Lathe maybe with a FANUC 11T controller you could share your parameter listing with me? Would be greately appreciated and would gladly repay if I could offer you help. Parameter Settings from 0000 to 9139 . . . see example below in picture. Machine manufacturer could not provide.
Old 09-05-2008, 07:14 PM
scottishgrant is on a distinguished road
http://www.mts-nw.com/parameters.html
try this
Old 09-09-2008, 09:46 PM
KustomKoncepts is on a distinguished road
try posting under the CNC lathes fourums or do a search on the name of your machine on the search bar on CNC zone and find others with your type of machine they will know more. where you posted here was under CNC WOOD ROUTER tables.
Old 09-09-2008, 09:49 PM
http://cnczone.com/forums/search.php?searchid=2781705
look here these guys have the same machines as you.
Later Man
Old 09-18-2008, 05:43 PM
opps . . . didn't see I was in wood working
Old 09-18-2008, 05:50 PM
We found an old print with parameters and was able to contact the machine builder with needed information and now have a backup if anyone needs them. Thanks!
Old 02-05-2009, 04:51 AM
kapostol is on a distinguished road
Hello,
We have the same machine, and the same problem you had. Could you please help me? We'd like to have those parameters.
Old 02-05-2009, 09:23 AM
Download from here http://cid-c4847dbd274a9918.skydrive...ork/ToyPar.zip
Dead Fanuc / Toyoda bluedemon Machine Problems, Solutions , Wireless DNC, serial port 14 01-26-2009 10:28 AM
Safe parameter settings for 730 and 731 1ctoolfool Haas Mills 0 06-16-2007 03:14 PM
Fanuc 16i and Toyoda RAC Fanuc 1 10-26-2006 07:28 PM
Fanuc 16i and Toyoda RAC General CNC (Mill and Lathe) Control Software (NC) 3 10-18-2006 07:48 PM
Fanuc / Toyoda FA630 ajl6549 General CNC (Mill and Lathe) Control Software (NC) 2 08-16-2006 08:44 PM
