Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > CNC Machining Centers
CNC Machining Centers Discuss wood cutting CNC machining centers, and Point-to-Point machines here.
Old 08-21-2008, 06:57 PM
Indywood is on a distinguished road
Question vacuum requirements
We are running a motionmaster router (I believe a 1430) with a Fagor 8050-55m controller, single spindle (Columbo) and a 5x12 table with a 20hp vacuum pump. I have 20 years in the business, but fairly new to cnc, and everything I think I know tells me this pump is way too small for this machine. I have a few ideas involving zoned valves to isolate sections of the table, but again I'm new at this and would love to hear from this community.
Old 08-31-2008, 11:45 AM
TheWoodCrafter is on a distinguished road
With a 5 x 12 table and if you are cutting a 4 x 8 sheet your effective vacuum is only 50% (10HP). It would be less because of the losses with the open table. Zoning or masks would be the cheap way out. Doubling you vacuum pump size would be expensive.
Try cutting 1/4 melamine and use it as a mask on the open table area not being used. This should make a big difference. Depending on how your table is built zoning may not be an option and using the mask may be the only way to go.
Old 09-19-2008, 10:50 AM
robinl is on a distinguished road
I use a 40 hp Decker pump.
Vacuum table and vacuum pump garagefela DIY-CNC Router Table Machines 19 01-25-2012 10:30 AM
PC Requirements runninwild400 Torchmate 4 07-07-2008 11:08 AM
IMService Kit Requirements Burn Benchtop Machines 61 08-28-2006 11:09 AM
PC Requirements Cyclone Computers and Networking 1 04-19-2005 08:57 AM
Power Requirements CapnC General Electronics Discussion 4 12-29-2004 10:39 AM
