Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > CNC Machining Centers
CNC Machining Centers Discuss wood cutting CNC machining centers, and Point-to-Point machines here.
Old 10-06-2004, 02:01 PM
Adriana is on a distinguished road
ortza Dart 815 any user??
I hope to find someone that can share some info, tips about this machines.
Im not new in CNC machines, but i used to work with italian machines SCM Routech. I use wood.
this is my first time working with this style of machines.
thanks a lot
Adriana
Old 09-22-2008, 10:36 AM
jjjr40 is on a distinguished road
Just bought two Ortza Dart 800 machines one has a cni410 and the other a cni500 controller, I believe that these are similar controllers.
Machines are not up and running yet but will be in the next 3 months.
jr
Old 09-22-2008, 12:51 PM
At least in all the forum, will be 2 Ortza users!! :-)
All the Dart´s use the same controlers, I guess by this time, you are waiting for the people who instal the machine, and give you some clues about the system, I meet some of them in Spain, last year.
I will be glad to talk about your experiences using the machines, soon.
regards!
Adriana
jr
Old 01-16-2009, 03:31 AM
Egurka Ortza Dart800chr problem
Finnally got the machines plugged in,
The first one is a dart800chr 2001 with a 6 posistion toolchanger on the left hand side, this machine just needs some TLC and some new nylon grippers for the tools.
The second machine is a Dart800CHR 2002 with a 9 posistion toolchanger on the Y axis however this one has an issue, after having done some electrical repairs all xyz axis will move beautifully as new.
Does anyone have any info on the following issues
1, Machine will not automatically size up (error - Time out rising router)
2, Manually moving the toolchanger causes the machine to trip out
Controls
NC500 controller with a RTU500 PLC
John
Old 03-04-2009, 09:51 AM
Allen123's Avatar
Allen123 is on a distinguished road
I need to find information about this machine the Dart 800 with a NEC 500 controller .
I believe the machine has come from Egurka
Please call me 727-744-2276
Old 06-18-2009, 03:18 PM
Jcwdhm is on a distinguished road
Exclamation Help using a Egurko Ortza Dart600
I am trying to construst a line that has a slope in and out. Meaning that I want my bit to gradually move at a downward slope while machining the line and then once a certain depth is reached I want to be able to make it start coming back up at an upward slope until the bit is done machining the line..... can anyone help me.
Old 06-18-2009, 05:19 PM
egurka ortza
what controller do you have with your machine
Old 06-23-2009, 08:41 AM
an NC 410 Deluxe
Old 07-15-2009, 07:06 AM
nc410
use the incremental z settings for changing the depth of a profile section whilst programming in EGA mode.
alternativly use the 3d infeed to automatically ramp into the board with a preset radius
Old 07-15-2009, 07:09 AM
Controls
John
Fixed machine wrong software was loaded originally
  #11   Ban this user!
Old 08-04-2009, 07:42 AM
I am running an older model cnc machine and I am trying to figure out how to write a parametric program for a door (303mm x 765mm) that has an arch. The arch's center point needs to be 62mm from the end of the board.... Everytime I make my board wider I want to write a parametric program so that the arch will expand with the board but the center point stay at 62mm....can someone help me. My controller is a NC 410
  #12   Ban this user!
Old 08-04-2009, 12:28 PM
MarkT is on a distinguished road
Your control should have door macros installed. The one you need to use is DOOR_1_S..I attempted to attach a screenshot of it, hopefully it worked.
To do it by long hand requires that you orient the door in the same manner everytime and use one of the arc EGA commands. Your equation for center point would then be 62 or X-62 depending on your orientation. You would also have to establish relationships with the start point and end points to the panel size to maintain the correct arc proportions.
If you send me a drawing of waht you want to ntek1@aol.com I can create one for you.
Hope this helps
Mark T.
