Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > CNC Machining Centers
CNC Machining Centers Discuss wood cutting CNC machining centers, and Point-to-Point machines here.
Old 05-26-2008, 11:23 AM
JOptionPane is on a distinguished road
formula?
Does anyone know the formula for cutting a piece to fit the pocket for inlay like if you were using a 1/32 bit and it came to a point what formula would you use to make the piece fit the pocket if the pocket came to point ?
JoptionPane
Old 05-26-2008, 11:25 AM
ger21's Avatar
You'll need to radius the corners 1/64". There's no formula. You'll also probably need to leave .001-.003 clearance. Trial and error will tell you what you need there.
Old 06-23-2008, 01:52 PM
Paul_S's Avatar
Paul_S is on a distinguished road
JoptionPane
What you are asking is too vague. formulas can be written for just about any kind of geometery to be cut.
Assuming(?) you want a slip(?) fit. Offset the geometery of the plug to be .001 to .002 smaller all around the periphery of the pocket. And for a point of some kind you will need to calculate the vector angle and offset the .001 to .002 90 degrees to it. There is not just one formula.
Safety - Quality - Production.
need a formula gravy General Metalwork Discussion 4 03-29-2008 07:38 AM
looking for a Formula rusticr6 Haas Mills 29 10-18-2007 10:23 AM
Need a formula Turk88 CNCzone Club House 3 06-15-2006 08:06 AM
What is the Formula? widgitmaster General Metal Working Machines 6 03-23-2006 10:35 PM
formula please! turmite General Electronics Discussion 2 11-22-2003 01:45 PM
