Results 1 to 3 of 3
Thread: Purchasing used industrial size cnc machine
    Apr 2008
    I make simple woodwork items and I'd like to add a cnc machine.
    I've shopped used industrial for other tools from IRS auction (industrial recovery,, not the tax aliens) and I've purchased with success.
    I see cnc machines used industrial size sell for a joke.
    Any comments/ideas on going that way for getting such a cnc machine?
    No problem with inspection, purchase, transport, off load, work space for it, etc. how about are they easy to work with the software? Can they be software changed easy (to windows based or simpler software if needed).
    Yes I know they don't compare to a $20k machine because they are more heavy and possibly more complex (multi tooling devices on the head) but if someone has no problem inspecting/trouble shooting/repairing such machines are they worth the chance?
    jim
    Mar 2003
    Shelby Twp, MI....USA
    A couple things.
    As for the control software, it depends how old they are. Just about anything 10 years old or older will be running a DOS based controller, if it uses a PC. And the PC will probably be 200Mhz or less (Mhz, not Ghz ). If the machine has multiple drilling heads, changing the control to something more modern may be very tricky to do, as a lot of machines use proprietary codes to control them. And alot of this control is done by PLC's, which may be hard to interface with (if possible at all). If it's a basic router, than the easiest way would be to rip out all the electronics and start over with new hardware that works with the control your using. Depending on your electronic skills and software choice, this can run from anywhere between $1000 to about $15-20,000.
    If it's a machine with drilling heads, and it runs, I'd leave it as it is. If it's just a router, I'd try it as is and only upgrade if it makes the machine easier to use.
    Parts will probably be very expensive, or impossible to get. Call the manufacturer and check on parts and service prices and availability.
    If it were me, unless it looks in nearly new condition, or the price is to good to pass up, I'd stay away from anything not running or more than about 8 years old. Unless you know exactly what's wrong and what it will take to fix it. Just my opinion.
    Jun 2007
    Check with the people at camsoft
    they seem to have an easy to retrofit Windows based PC system
    it is very affordable.
    The website has some videos of retrofit machines operating
  1. MACHINE SIZE
    By LYN BYRD in forum Mach Software (ArtSoft software)
    Last Post: 04-17-2008, 01:42 PM
  2. Servo size for this machine
    By XLR84x4 in forum DIY CNC Router Table Machines
    Last Post: 06-08-2007, 02:11 AM
  3. Looking for advice on purchasing a machine
    By DublD in forum General Metal Working Machines
    Last Post: 10-09-2006, 04:04 AM
  4. Servo size for this machine?
    By DennisCNC in forum Mechanical Calculations/Engineering Design
    Last Post: 04-19-2006, 09:24 AM
  5. What size machine to build?
    By CNCMP in forum DIY CNC Router Table Machines
    Last Post: 01-04-2005, 02:36 PM
