Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > CNC Machining Centers
CNC Machining Centers Discuss wood cutting CNC machining centers, and Point-to-Point machines here.
Old 03-04-2008, 02:31 AM
Rust is on a distinguished road
Busellato Jet 2000
Having problems with a reacurring cycle error (Digital input main. Elman 2 Bas Waiting off). Is there anyone that knows what this means and how to fix it. Its stoping programs mid cycle, tool changes seem to be a bit sluggish just befor error message apears.
Old 03-10-2011, 10:43 AM
Rob@milford is on a distinguished road
Rust,
We experienced the same problem with both of our Jet 3006 machines in the past. I can't recall if it was caused by the sensor on the tool carousel, that reads the toolholder location prior to the tool change or if it was the internal sensor that checks the seating of the toolholder in the electrospindle (I believe it was the latter).One machine just required a good air cleaning of the electrospindle and a thorough cleaning (with scotch brite) of all the toolholders, particularly the surfaces that contact the electrospindle. The other machine improved for a while after the same treatment but eventually would not make it through a tool change without shutting down even after a thorough cleaning. The operator tried a trick he picked up at a previous job and dropped a thin flatwasher into the machine end of each toolholder and the machine has run flawlessly since (approx. 2 years).
Old 10-20-2011, 02:52 PM
joe_mcdaid is on a distinguished road
Hi I use a Jet2000 and it's shows up the same error.
Rob@milford what exactly did your co-worker do when he "dropped a thin flatwasher into the machine end of each toolholder "
Busellato vs Weeke MARKC53 Commercial CNC Wood Routers 11 11-22-2011 05:33 PM
Busellato Problems mcmxl22 Commercial CNC Wood Routers 4 09-03-2009 09:20 AM
V Carve pro and Busellato JET 3006 Vectric 23 03-07-2008 04:10 AM
Busellato Optima Point To point Malacara General CNC (Mill and Lathe) Control Software (NC) 0 12-11-2007 06:22 PM
2000 RPM new TL-1 xyzcnc Haas Mills 2 04-19-2006 10:10 AM
