Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > CNC Machining Centers
CNC Machining Centers Discuss wood cutting CNC machining centers, and Point-to-Point machines here.
Old 12-03-2007, 10:18 PM
SIG SIG is offline
SIG is on a distinguished road
Draw bar tension
I have a Doosan 3016L and I notice that the holder twists in the spindle if the retension knob is a quarter turn loose. Shouldn't the draw bar be pullling about 1800lbs.
Thanks,
SIG
Belt Tension Options?? flash319 DIY-CNC Router Table Machines 5 09-19-2007 02:06 PM
Torch tension input for a PIC [ THC ] MaXx General Electronics Discussion 4 05-13-2007 07:23 PM
Tension/compression tap holders Caprirs General Metalwork Discussion 8 04-05-2007 07:59 AM
Wire tension gguidi CNC Wire Foam Cutter Machines 1 10-20-2006 09:40 AM
Belt Tension Adjuster Design mxtras Mechanical Calculations/Engineering Design 8 05-16-2005 10:33 AM
