Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > CNC Machining Centers
CNC Machining Centers Discuss wood cutting CNC machining centers, and Point-to-Point machines here.
Old 10-10-2007, 10:31 AM
jorgehrr's Avatar
jorgehrr is on a distinguished road
Smile Absolute and relative
I'm new with machine centers.
I mix both when I program lathes (X,U) (Z,W) with out any G code just input the address.
In machine centers can you do the same or you need the G code?
Also, I see an "A" in one of the programs what axes does this have relation with.
Thank you in advance.
Jorge
Old 10-10-2007, 10:36 AM
Al_The_Man's Avatar
A axis will be rare on a lathe, but the convention is that A rotates around X.
B rotates around Y & C rotates around Z.
A,B,C axis for rotary tables for e.g.
On a lathe, if the spindle is used for a Rotary, then it is C axis.
Old 10-10-2007, 11:01 AM
jorgehrr's Avatar
Thank you Al,
Here is a couple of blocks where I see the "A". I really do not understand why the "A" is in there.
N4 T1 M6
N6 G0 G90 G54 X0. Y0. A0. S1426 M3
N8 G43 H1 Z1.
N10 Z.1
N12 G1 Z-.3 F6.3
Thank you
Jorge
Old 10-10-2007, 11:27 AM
Originally Posted by jorgehrr View Post
Thank you Al,
N4 T1 M6
N8 G43 H1 Z1.
N10 Z.1
N12 G1 Z-.3 F6.3
Thank you
Jorge
A is the 4th axis on a VMC which would be a rotary table mounted on the machine table with the axis of rotation horizontal and parallel to the X axis.
On a machining center Absolute and Incremental (Relativee) commands are selected by G codes; G91 is Incremental, G90 is Absolute.
Old 10-10-2007, 03:42 PM
jorgehrr's Avatar
Thank you guys for your help.
Jorge
Fanuc 0M.. how do you zero relative? OC_ Fanuc 5 02-23-2007 10:45 PM
relative position Rocksalt Fanuc 2 10-24-2006 02:17 PM
x/y absolute dimensions (how?) corpse Solidworks 5 02-03-2006 11:31 AM
Absolute encoders? murphy625 CamSoft Products 10 03-28-2005 09:18 PM
Absolute and Incremental ACME G-Code Programing 3 09-04-2004 05:45 PM
