Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > CNC Machining Centers
CNC Machining Centers Discuss wood cutting CNC machining centers, and Point-to-Point machines here.
Old 09-14-2007, 11:33 PM
longcut is on a distinguished road
Sharp 2412 tool changing problem
Actuator/cylinder is not releasing the retension knob fingers do to lack of travel. Any suggestions?
Old 09-15-2007, 05:02 AM
davereagan is on a distinguished road
I had that problem with my Mighty machine a couple of years ago. After a whole lot of trouble, I got it working again without being really sure what it was. I was not down on hydraulic fluid, but that would be my first recommendation: there is probably an air over hydraulic cylinder in the back of the machine. The force needed to release a tool is higher than can bemade with 90 psi shop air without the use of an enormous cylinder, so they make hydraulic pressure and use a smaller cylinder. You likely are down on fluid and there may be air in the system even if you replenish the fluid. Feel free to email me at davereagan@hotmail.com with any questions. A call to the dealer might help. Personally, I'll spend days trying to fix a machine myself before calling them in at $95/hr with a 4 hr minimum. I've saved thousands over 8 years just learning to fix tool jams, spindle orientation, backlash adjustment, electrical shorts,etc.
Sharp SV-2412 Larry B. CNC Machining Centers 18 10-12-2007 08:58 AM
Postprocessor for Faunc Oi Mate-MB on Sharp 2412 Mickey_D SprutCAM 2 07-21-2007 05:51 AM
6M quit tool changing Drew Fanuc 0 01-23-2007 12:32 PM
Tool changing G30.1 ben92 G-Code Programing 0 11-17-2005 01:57 AM
' 04 VF 4 Rough Tool changing ap-machine Haas Mills 16 09-26-2005 07:56 AM
