| CNC Machining Centers Discuss wood cutting CNC machining centers, and Point-to-Point machines here. |
I have a sharp 2412 vertical machining center (10 pos tool changer) and it has developed a problem clamping the tool. It appears the cylinder/actuator is not letting the collet fingers come down far enough to grab or release the tool. Air pressure is fine and I pulled the hose from top of cyclinder and there appears to be sufficient pressure. Any ideas???? Thanks, Matt |
| Symptoms can be deceiving such as a bent finger, taper lock........... usually the stroke is adjustable and is set at the factory and RARELY changes. Many machine tools have tool "kickout" where the drawbar ass'y strokes far enough to hit the top of the retention knob of the toolholder and push it .05" downward. Look up in the spindle for damaged fingers. Change tools by hand, paying attention to the tool release and see if it pushes the tool down into your hand at least 1/32" |
| VF-2SS Tool Carousel Problem | JoBwan | Haas Mills | 18 | 05-25-2011 01:07 PM |
| What will cause this tool setter problem? | Hogger | Daewoo/Doosan | 3 | 01-03-2007 07:52 AM |
| Big problem. Tool stuck | Tien_Luu | General CNC (Mill and Lathe) Control Software (NC) | 0 | 08-04-2006 03:46 PM |
| Mazatrol T32 Turret Clamping problem | sunrock_83 | Mazak, Mitsubishi, Mazatrol | 5 | 02-08-2006 10:38 AM |
| getting tool path problem | kenlambert | BobCad-Cam | 0 | 01-14-2005 02:15 PM |
