Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > CNC Machining Centers
CNC Machining Centers Discuss wood cutting CNC machining centers, and Point-to-Point machines here.
Old 08-10-2007, 09:14 PM
BruceinOZ is on a distinguished road
new to cnc machining center
I have a question about setting the center of a round piece of material to X0 y0.
What is the easiest way to find the center ? Do I have to do it on the x & y axis or is there another way. I can find it using the x & y axises but it takes forever to do it.
Old 08-10-2007, 09:43 PM
tobyaxis's Avatar
Moderator
tobyaxis is on a distinguished road
How are you holding the Material, in a Vise, Chuck, Clamped to the Table or in a Fixture???
Toby D.
"Imagination and Memory are but one thing, but for divers considerations have divers names"
Schwarzwald
www.refractotech.com
Old 08-10-2007, 09:48 PM
bborb is on a distinguished road
No real easy way but you can use an edge finder and touch off the left side and zero X axis, then jog over to the right side and edge find off that side, look at your position and divide the X value by two and jog to that value in X, then zero X and you're very close to center.
Old 08-10-2007, 09:56 PM
The easiest way to find the center of a round piece or a hole is a Coaxial Indicator. This mounts in the spindle and has a dial gauge held stationary by an arm that rests against something fixed to the spindle (I pull down the coolant nozzle) and a probe that rotates with the spindle and goes around the part. When the spindle axis and the centerline of the round part are inline the dial gauge does not deflect.
Google 'coaxial indicator' or Blake Indicator' or combine them both. Blake manufacturing is a US company that makes a very good coaxial indicator; cheap import are available but not worth buying in my opinion.
Old 08-10-2007, 10:14 PM
tobyaxis's Avatar
Moderator
I believe that someone here on CNC Zone tested one at 3000 RPM LOL. I failed the test but a lesson was learned.
Toby D.
Schwarzwald
Old 08-11-2007, 12:17 AM
Eurisko is on a distinguished road
I use an Interapid dial indicator, very well made.
Years ago, I was zeroing a very small bore on a Giddings & Lewis Machining center. This was an NC machine, not CNC.
As I pressed the buttons to zero the X & Y axes, the spindle suddenly dove straight down, forcing the larger indicator into the smaller bore. What a mangled mess...
G&L's were very unpredictable machines.
Old 08-11-2007, 01:25 PM
tobyaxis's Avatar
Moderator
Well, we all learn what to do and what not to do. That's just the way it is.
Toby D.
Schwarzwald
D&M 4 machining center Documentation? cthomas Benchtop Machines 64 04-05-2012 04:53 PM
HOW BIG IS YOUR CNC Machining Center? boxxer_boy CNC Machining Centers 5 04-10-2007 05:31 AM
Machining from center or zero corner Bill1 Moldmaking 9 08-28-2006 07:00 AM
D&M 4 Machining Center bill south General Metal Working Machines 0 07-17-2006 05:21 AM
New Machining Center porsche1220 CNC Machining Centers 0 04-27-2006 06:34 PM
