Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > CNC Machining Centers
CNC Machining Centers Discuss wood cutting CNC machining centers, and Point-to-Point machines here.
Old 08-07-2007, 07:43 AM
Mussel Kar is on a distinguished road
Weeke BP12 won't work.
The battery went dead and the machine lost the bios setup info so that the PC could not find the hard drive. I had Stiles recover my hard drive and mirror it onto a brand new drive. They said everything was recovered so I put it all back together and had the same problem. Guess the battery was weak. I reset the setup in the bios and when the DOS part booted it showed a floppy drive, a fixed drive, a parallel port and 0 serial ports. I can't find anything in the bios setup to turn on a serial port, only something to set baud rate, etc. I'm frustrated at this point because it takes a long time for them to return phone calls. Any Win 3.11 gurus out there. This machine is 12 years old and runs Win 3.11.
Busellato vs Weeke MARKC53 Commercial CNC Wood Routers 11 11-22-2011 05:33 PM
Weeke Machine anyone? DennisCNC Commercial CNC Wood Routers 6 05-03-2008 08:57 PM
More Weeke problems... gatorman Machine Problems, Solutions , Wireless DNC, serial port 5 08-03-2005 05:51 PM
Weeke Spindle Problem gatorman Machine Problems, Solutions , Wireless DNC, serial port 2 07-22-2005 03:26 AM
will this work? campaX DIY-CNC Router Table Machines 8 05-17-2005 12:42 PM
