| CNC Machining Centers Discuss wood cutting CNC machining centers, and Point-to-Point machines here. |
i'm having an issue when i run material in a mirrored field. my Busellato Jet 4000(1999) which runs off Genesis, parks the head to the far right when running in a normal field. but when i run material in a mirrored field,which is on the right, it still parks to the right, which is now in my way when the operation is complete. any idears? i notice whenever i write a program through Genesis or even post through MasterCamX(with Busellato post add-on), it'll automatically end any operation with a "MO2" code,which i believe is the parking command. i've tried to manually rewrite the code to "MO1" or "M03", but it won't accept that line. thanks-Mike |
| N.V.M., The M02 command is only a misc. G-Code that thats purpose is to stop the program. Within the Genesis folder you will need to Technical Parameters file and within the Axis Data or Head Data there a fields which you specify the cordinates of the park positions and which is used for which working zone. I did this from memory, so if you have any problems call Delmac and they can guide you through this easily over the phone. Hope this helps! Mark T. www.cnccustomservices.com |
| thanks Mark, i'll poke around in the Parameters again tomorrow and let you know. and Delmac won't help me because believe it or not, i'm not in the U.S.A. you know how territorial these industrial machine companies are. i usually have to phone Italy directly to get answers. |
| 5t problems | markjb | Fanuc | 16 | 11-30-2011 11:36 PM |
| KMB-1 problems | MTMW | HURCO | 4 | 07-22-2007 03:40 AM |
| G2 Arc problems | CharlesM479 | G-Code Programing | 8 | 03-01-2007 06:48 PM |
| TM-1P problems | tmt_92021 | Haas Mills | 1 | 10-17-2006 01:22 PM |
| 85 vmc 40 problems | tractdesign | Fadal | 0 | 01-17-2005 04:15 PM |
