Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > CNC Machining Centers
CNC Machining Centers Discuss wood cutting CNC machining centers, and Point-to-Point machines here.
Old 07-16-2007, 03:47 PM
YorkyJD is on a distinguished road
Thumbs down Record 110 and Xilog Plus
We have a record 110 which I am responsible for programing and am getting on great I just have on thing that occasionally catches me out, imagine trying to cut a squre hole in a piece of timber where the off cut is to small to catch so I would tend to make a number of passes producing sawdust until the hole is the required size. Now all works well until the tool diamete chages as a resharpen this obvioulsy affects how much i can remove on each pass.
Now the question is it possible to retrieve the diameter for the tool currently loaded into the spindle under xilog plus ? This would solve my problem,
Thanks in hope
JD
Old 07-23-2007, 12:05 PM
mut mut is offline
mut is on a distinguished road
yea you can mate.
theres a whole load of information you can call up about your tools,
on my record 100al, id use the following:
L VARNAME =(TOOL(102, 10))
that sets a variable called varname which has the diameter of tool 102
hope that helps.
tom
Old 11-12-2011, 02:29 PM
dazzler is on a distinguished road
The way we do it, is machine the square hole as a pocket. After a regrind measure the diameter and input those details into your tool file, usually it is a def file, then fixed tools. Hope taht helps.
Old 03-01-2012, 02:23 AM
timberman is on a distinguished road
you have to measure the tool diameter & enter it into your tool file so whats the problem
Old 03-01-2012, 11:45 AM
jweinhold is on a distinguished road
Make sure to leave some stock there and make a final pass using tool comp. C=1 or C=2. Pocketing does not use tool comp.
SCM Record 121 craigy85 Commercial CNC Wood Routers 1 03-08-2008 04:38 PM
Licom To Xilog Plus mnchaos CNC Machining Centers 3 07-09-2007 10:10 AM
surface machining + xilog Shawnm General CNC (Mill and Lathe) Control Software (NC) 7 10-17-2006 08:55 PM
Position Record ...Bad thuffner3 TurboCNC 4 02-09-2004 05:16 AM
