Results 1 to 5 of 5
Thread: help g code
    Jul 2007
    england
    help g code
    hi can sombody help me with programming g code, i only need a simple program to run a 3 axis milling machine. im getting stuck with G01 makinhg circles can sombody send me a program please and help explain how to do it
    thank your time cody
    Jun 2007
    Norway
    you cannot machine a circle using g01 unless you break your circle into very small segments to make it smooth enough. use a g02 or g03(circular interpolation) command with R address for specified radius for semi-circles and I,J,K addresses for full circles. you can also use the I,J,K addresses for semi-circles but that could be a little confusing for a newbie.
    Jul 2007
    england
    thanks for the help can u show me an example befor i get realy confused. making the machine w3as easy i didnt thing=k g code would be so hard. so yea can u show an example of moving the tool and cutting i.e
    f400
    G00 y50 x50
    and here i want to cut a circle of 43mm diameter. so i need to bring z down in very slow stages as i want to cut aliuminium
    Jun 2005
    us
    Here is a link for a free circle cutting program by kentec.
    http://www.kentechinc.com/tip7.html
    Tim
    Jul 2007
    england
    thnks
    cheers for the help guys probably b bk soon with another problem
    1. Wierd NC Code and G-Code
      By Tazzer in forum General CAM Discussion
      Last Post: 01-09-2012, 02:07 PM
    2. To hand Code? or to CAD Code?
      By automizer in forum Polls
      Last Post: 11-26-2011, 10:30 PM
    3. learning g code or cad-cam code output?
      By slow_rider in forum G-Code Programing
      Last Post: 02-27-2010, 09:48 PM
    4. G-code for beginners - want to learn G-code
      By FPV_GTp in forum G-Code Programing
      Last Post: 11-18-2008, 12:25 AM
    5. looking for g code 3d from bobcadcam or simmilar for indexer lpt v5 with g code soft
      By troyswood in forum Ability Systems - LPT Indexer and G-Code
      Last Post: 12-24-2006, 10:21 PM
