| CNC Machining Centers Discuss wood cutting CNC machining centers, and Point-to-Point machines here. |
| hello all, i'm new to the fourm. i have a kitamura mycenter zero and i am getting a servo y axis alarm. the alarm on the servo says -bb? it's a yasnac control and i am running a rotary phase converter. i think it could be a voltage problem. i measured the voltage and the company where i work and it is at 208V steady. my voltage is 255V please help if anyone can tell me what's going on. |
Arty, Yes, that incoming line voltage is a little high for Japanese equipment (which mostly is designed for 200VAC). However, the Yaskawas I've worked on recently show "bb" when the drives are up,enabled, and error free. Could you have some other problem? Yaskawa has pretty good on line resources. Have you downloaded the book on your drives yet? Warren www.uptimecorp.com |
| I agree, typically on Yaskawa Drives "bb" means "base block" which means the drive is functioning correctly to make the transition to the "run" state. "run" is the normal condition for the axis drive when running. If an error occurs while the drive is running, the "run" will change to an alpha numeric designation (example "AE6"), you would then have to look the error up to begin troubleshooting. Hope this helps! Mark T. www.cnccustomservices.com |
| That voltage is WAY HIGH!! You have to drop it. If not, you will see that you will increasingly have more and more electrical issues. Also, what kind of converter are you running on? Be aware that if it is not "balanced for CNC use" you are taking your chances. |
| Kitamura MyCenter 2 VMC Fanuc 6m | Yabbos | Fanuc | 25 | 09-03-2009 03:16 PM |
| 1981 KITAMURA Mycenter 2 trigger output | moldmker | Fanuc | 4 | 06-28-2008 04:02 PM |
| kITAMURA MYCENTER-1 Help needed again!! | aghobby | Fanuc | 5 | 07-11-2007 02:53 AM |
| Kitamura Mycenter 0 | inertialabs | Shopmaster/Shoptask | 0 | 01-15-2007 08:47 PM |
| Kitamura Mycenter 1B Specs | Nauticalknowhow | General Metalwork Discussion | 1 | 12-27-2006 12:03 PM |
