Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > CNC Machining Centers
CNC Machining Centers Discuss wood cutting CNC machining centers, and Point-to-Point machines here.
Old 04-24-2007, 05:43 PM
Malacara is on a distinguished road
Point to Point Busellato
Hello everybody.....This is my first time here....
I am getting this message "PTP link Open" from my Busellato Point To Point I have tried severals thing trying to fix it but I couldn't.... If you know something about that I will appreciate your help....Thanks.
Malacara....
Old 04-26-2007, 06:43 AM
Blaine is on a distinguished road
Malacara,
It would be helpful to know the year the machine was made, the model, and the software the machine is using.
But generally speaking, the error you mentioned indicates you are losing serial communication between the PC and the controller.
The cable between the PC and the controller should be checked, the COM port of the PC, and the controller itself, which hopefully is not the problem, as they are expensive to replace.
Overheating can cause this error as well, so make sure the fans are all working, and air filters clean.
Good luck,
Blaine
Old 04-26-2007, 12:13 PM
Busellato Optima\CWA, Matricula 020396 and the software that the machine is using is Winner 90,,,,, Thanks for the advice Blaine,,,,,I going to check....
Malacara....
Old 05-01-2007, 05:41 PM
AndrewN is on a distinguished road
Good to see that Blaine is here to help.
Andrew
find the point? TURN ME General Metalwork Discussion 48 09-02-2006 11:15 PM
tangent point bob in windsor General Metalwork Discussion 11 12-23-2005 03:05 PM
Point Clouds Freddy Rhino 3D 6 11-10-2004 05:32 AM
Point Cloud Freddy Digitizing and Laser Digitizing 4 09-23-2004 10:18 PM
Point clouds kdoney Rhino 3D 3 05-21-2003 05:37 AM
