Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > CNC Machining Centers
CNC Machining Centers Discuss wood cutting CNC machining centers, and Point-to-Point machines here.
Old 04-08-2007, 11:45 AM
asjad is on a distinguished road
Red face Thread milling help!
I want to make a programme for inside thread milling by interpolation method using single point thread milling cutter ......
how can i make programme for 28 mm inside core dia with 1 mm pitch in 25 mm depth........
If i have got dia 10 mm single point HSS cutting tool.
Old 04-08-2007, 02:49 PM
This program has the Work Zero at the center of the hole and Z zero at the top of the material and it uses Tool Compensation which is entered by the G10 command. I have not accurately calculated the diameter for the thread so you would need to do that, I am just using 30mm to make it easy. Also this is just the thread milling part so you would need to interpolate the hole first.
G10 L12 G90 P1 R10.0 Enter the tool diameter
G00 X0. Y0. Z1. Move to the hole center
Z-25.0 Move to the starting depth
G41 D01 G01 Y10. F25. Set tool compensation but do not enter the cut yet
G03 R12.5 Y-15. This does a halfcircle counterclockwise so the tool enters the cut tangentially and ends at a radius of 15mm G91 G03 I0. J15. Z1. L26 This does 26 circles incrementing up 1.0mm at each circle so the tool ends above the work
G90 G40 Y0. Z1.0 This changes back to absolute, cancels tool compemsation and move clear of the work
Old 04-10-2007, 07:27 AM
Thumbs up
thanks you *Geof* i have made the same programme myself ... i wanted to know more techniqs..... anyway my job is done thanks again.
Old 04-10-2007, 01:47 PM
dandy is on a distinguished road
try this website www.advent-threadmill.com/
I use their software for 90% of my thread milling
dandy
Old 04-12-2007, 05:08 AM
boxxer_boy is on a distinguished road
I know that one of our tool suppliers has a neat little porgram that you can download from there site.. the company is ISCAR.
Old 09-21-2008, 11:47 AM
tturnbull50 is on a distinguished road
thread milling macro
try this I use it on fanuc O-M + 18
It is in metric but can be used for imperial as well
T1
M6
G0G54X0Y0S2000M3
G43Z100.H1M8
M98P4000
G0X50.
M98P4000
Z100.
M30
:4000 (THREADMILL)
#100 =-62.(START DEPTH)
#101 =10. (RADIUS OF THREADMILL)
#102 =42.(DIAMETER OF THREAD)
#103 =150 (FEEDRATE)
#104 =2.(THREAD PITCH)
#105 =12.(TIP LENGTH)
#102 =#102/2.
#102 =#102-#101
WHILE[#100LT0]DO1
G1 G90 Z#100 F500
G1 G91 X#102
G3 G90 I-#102 Z[#100+#104 ]
G01 G91 X-#102
#100 =[#100+#105+#104 ]
END1
G0 G90 Z10.
M99
Thread Milling Don Clement Tormach PCNC 23 08-01-2011 07:48 PM
0M-Thread milling? mikul Fanuc 1 12-06-2006 12:56 AM
thread milling STS_Kevin Daewoo/Doosan 0 11-28-2006 07:50 PM
Thread Milling 3/8-18 NPT shawn G-Code Programing 13 08-26-2006 09:24 AM
Thread milling, can anyone help jtrav General CAM Discussion 16 03-06-2006 03:25 PM
