Results 1 to 4 of 4
Thread: Auxilary m codes
    Dec 2011
    Auxilary m codes
    I have a Haas VF6 50 taper and am trying to write a program that will turn on then turn off a electric punch. I am using M24 to turn it on but can't find the proper code to turn it off without hitting the reset button. My full program will quite lengthy. It will require the punch to function 32 times per run.
    May 2004
    If the control is not equipped with the M-code relay board, then M21 through M28 will be mapped from #1132-#1139. If the M-code relay board is installed, see the 8M-option section for information and instructions.
    http://www.kirkcon.com/
    Dec 2011
    I installed the M-code relay board before I started messing with try'ing to get the punch to work. What and where is the 8M-option section that you are refering to? My server won'y let me go to the kirk site.
    May 2004
    It is still early enough in the day, you can contact:
    Haas Automation, Inc.
    2800 Sturgis Rd.
    Oxnard, CA 93030
    Phone: 805-278-1800
    Toll Free: 800-331-6746
    No idea why you cannot connect to my business site. It is hosted by a major web hosting company and other access it just fine.
  1. Need Help!- G codes and M codes for Mazak Quick Turn T-2
    By sauli in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-23-2011, 12:22 PM
  2. G codes M codes Mach3
    By eaglezsoar in forum Mach Software (ArtSoft software)
    Last Post: 02-03-2011, 06:38 PM
  3. Need Help!- Need full list of G CODES AND M CODES FOR FANUC 21I
    By SonnyTees.com in forum G-Code Programing
    Last Post: 02-23-2010, 11:27 AM
  4. Running an indexer from the auxilary socket
    By ANGAENGINEERING in forum Fanuc
    Last Post: 10-12-2009, 08:50 AM
  5. M-codes and G-codes 4 Matsuura ES-1000V
    By maximusek in forum G-Code Programing
    Last Post: 11-27-2007, 07:41 AM
