Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > CNC Machining Centers
CNC Machining Centers Discuss wood cutting CNC machining centers, and Point-to-Point machines here.
Old 01-31-2012, 12:30 PM
cbkrahn is on a distinguished road
Points on a circle (Biesseworks question)
Hi, my maths have failed me, so I must venture out into the great unknown and ask the internet for help!
Attached is a picture of a circle and a rectangle. The arc formed on the rectangle by the circle is the arc that I wish the rectangle to possess (the circle is for illustrative purposes only). I'm having a problem figuring out how to determine where the points of intersection are.
The centre of the circle is LPX,LPY. The radius is LPX minues the space at the top.
I've been staring at Visual Basic codes and circle math problem online for a couple hours now and am still no closer to an answer than when I began. Hopefully somebody knows more about this stuff than I do!
Old 01-31-2012, 01:05 PM
KOC62's Avatar
KOC62 is on a distinguished road
Well, if I understand the drawing, you didn't give enough data.
First, the radius doesn't change so it intersects both points on the square. I would draw a line from each point back to your center of the circle. Now you have formed an isosceles triangle. To solve the rest you need enough data, to calculate the points on the triangle formed.
Old 01-31-2012, 01:56 PM
The tangent is the same length as the radius. The height of the triangle formed is, in this case, 127mm (the rectangle is equidistant from the left side, top, and bottom.
Any other data I'm missing?
LPX=2032
LPY=762
Top, Left, and Bottom space =127
Radius=2032-127
Old 01-31-2012, 03:04 PM
KOC62's Avatar
Here is my thinking.
I'm assigning;
Cx = 0
Cy = 0
Lower desired left side point = P1
upper desired left side point = P2
By inspection of your graph;
P1x = LPx -127mm = 1905 mm
P1y = Cy + 127mm
P2y = LPy-127 = 762 - 127 = 641 mm
P2x = Cx + ?
We know P2y, so it forms the "opposite" side of a right angle triangle with the radius forming its hypoteneuse. Then P2x = the "adjacent side of the triangle.
Knowing two sides of a right angle triangle you can calculate the angles so that you can calculate the adjacent line.
I'll leave that as your homework since I didn't go that far.
Or use pythagorean theorem. All the necessary info you now have.
Old 01-31-2012, 11:15 PM
Kiwi is on a distinguished road
You asked a math question about step runners over six weeks ago and never looked at the replies. Why should anyone bother to answer your questions?
Old 02-02-2012, 08:56 AM
Dude, my question was answered and the problem solved. I was able to work it out in part from the information you gave me too. Apologies for not saying 'thanks', but I don't get paid to surf forums.
Old 02-02-2012, 09:20 AM
holbieone's Avatar
holbieone is on a distinguished road
Trig. It out , solve for a right triangle
Old 02-02-2012, 11:26 AM
When the boss said to learn how to use a CNC, he didn't inform me I needed trig.
Anyways, after 2 hours of trying every combination of trig I could come up with, none of it works. I used the ATN function and the pythagoream theory and neither of them seemed to work. After about 2 hours I took a line with the length of my radius and ran it from my origin point, only to discover that Biesseworks was drawing the circle I was using as a reference wrong. So I lost 2 hours to a rendering error.
Ah well, learning every minute. Works fine now!
Old 02-08-2012, 04:56 AM
... but I don't get paid to surf forums.
Jerk..Members who answer questions don't get paid for their time either. Looks like your getting paid for a job that you can't handle.
biesseworks Tommy the Cat Want To Buy...Need help! 0 05-24-2011 04:12 AM
Help with Biesseworks als12 Commercial CNC Wood Routers 36 03-24-2011 10:52 AM
write gcode for circle with 4 small circle inside it Farzaneh_2010 G-Code Programing 3 12-13-2010 10:24 AM
Turbocad/cam and biesseworks tkran TurboCAD/CAM 0 09-15-2008 05:56 PM
Biesseworks programing cci-mule Canadian Club House 1 08-16-2008 03:18 PM
