Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > CNC Machining Centers
CNC Machining Centers Discuss wood cutting CNC machining centers, and Point-to-Point machines here.
Old 11-06-2005, 05:23 PM
ahmedsamy_81 is on a distinguished road
Problem in tool change
i had writen my first G-code on CNC machine(Milling machine) but when the program began in tool change the Head was rotated and the magazin start to rotat continuously without stop , i think first the problem in the tool memory.
but i need help for how i can solve this problem
Old 11-06-2005, 06:01 PM
HuFlungDung's Avatar
Moderator
When you started up the machine, did you first send the 3 axis to the home position, and then the toolchanger to the home position?
Old 11-07-2005, 03:25 AM
How that?
I'm already sent the 3 axis to the home position by doing calibration to the machine.
But how i can send the toolchanger to the home position?
Old 04-15-2006, 12:36 AM
flinty is on a distinguished road
Very easy answer, get your boss to buy the programming manuals I got ready for you and all the answers you seek are there in the books.
vamvany
Old 02-21-2007, 01:23 PM
SKIP HELLAND is on a distinguished road
Did you try index the turret or magazine in mdi? Also,what is on that line of programing? to6m6; ?Try that then run your program.
Old 03-28-2007, 04:35 PM
ben_heinman is on a distinguished road
Tool change position
If the machine is a double column you can do G30 Y0. Z0.; If it is just a single and zero return is not the same as tool change position then G30 Z0.; should do it. Also make sure all your tool address are set to different numbers.
