Results 1 to 3 of 3
Thread: biesse works question
    Nov 2011
    australia
    Hi everyone, we just recently bought a biesse klever and i wanted to no, how can we program the machine so when its cutting, it would cut the smaller pieces first? Because it normally cuts the bigger pieces and would leave the small pieces to last and then it doesnt have enough vacuum on the small piece and sometimes moves a bit.
    Thanks!
    Aug 2011
    cutting small pieces first
    I know you can call Biesse and they will help you out, but there a few different ways to do this.
    1 - when designing small pieces in Biessworks, go to the second tab in the milling setup (additional data page) and uncheck "(ISO) ISO instruction" this will keep the small pieces from being optimised when you nest and these pieces should be cut first.
    2 - (this one requires two router bits) create two router bits and set one to "rout1" and the other to "rout0". Go into the class management and set the priority of "rout0" to 3 and "rout1" to 5. When designing small pieces in Biesseworks, use "rout0" and then use "rout1" for other pieces. When optimised and run the higher priority pieces are cut first.
    Again, I would call Biesse for some help. It has been a while since I programmed
    Mar 2003
    Shelby Twp, MI....USA
    We use a utility in AlphaCAM to batch process our .dxf files, and it automatically onion skins small parts, and cuts them out first.
  1. Need Help!- Only Y works correct X don't work Z works one direction only
    By jdgbadenhorst in forum Hobbycnc (Products)
    Last Post: 06-10-2012, 04:54 PM
  2. Biesse rover 316 controller ID question
    By 67barracuda in forum CNC Machining Centers
    Last Post: 11-13-2011, 12:16 PM
  3. Need Help!- Solid Works 2007 Question
    By SPEEDRE in forum Solidworks
    Last Post: 03-06-2011, 07:50 PM
  4. biesse 336 parametric question
    By bamstik in forum Parametric Programing
    Last Post: 03-01-2011, 05:10 PM
  5. Biesse
    By eng_semsem1980 in forum Commercial CNC Wood Routers
    Last Post: 07-26-2007, 05:32 AM
