Results 1 to 4 of 4
Thread: Vacuum Pump Overheating
    Jan 2011
    HI all,
    We are currently running a Rover322 (1994). Our vacuum pump is overheating and can run for about 10 minutes before shutting off. We were told that the bearings are going and causing the overheat.
    We were able to get a replacement pump and we are experiencing the same results.
    Original pump Becker VT3.40 installed Becker VT3.100? (5HP)
    Exact same end result.
    Does anyone have a resolution for me.
    Notes: Air filter and relief valve removed, vacuum line connected directly, machine not in operation and vacuum pump running, 10 runtime max
    Thanks in advance
    Registered Boltz's Avatar
    Mar 2010
    leak?
    Are you pulling normal amounts of vacuum? My Becker heats up when the vacuum dips below 20" and the flow goes up. I smell the overheated oil long before anything trips, though.
    -Jim Hart
    My main machine: Multicam MG series (MG101) with original Extratech H971 controller, Minarik servo motors, Electro-Craft BRU-series drives, 4KW Colombo. Let's talk Multicam!
    Jan 2011
    Hi Jim
    Is holding vacuum at about 24" (non operating) during operation drops to 22".
    These were normal readings for us, this pump issue is only about 3-4weeks in.
    We use the machine for mdf cabinet door manufacturing
    We are new to the CNC operation, only about 7 months now.
    Jan 2011
    vacuum overheat
    If the pump is exposed to the mdf dust, this stuff gets into everything and can cause a real problem! pull your seperator top and check to see if you have dust in the bottom of the tank! Also if the dust settles on the pump, it can cause it to run hot! If pump is shutting down on high temp, try replacing the high-temp cut out switch!
  1. Vacuum table and vacuum pump
    By garagefela in forum DIY CNC Router Table Machines
    Last Post: 01-25-2012, 11:30 AM
  2. Newbie- Vacuum Pump
    By WoodMizer in forum Commercial CNC Wood Routers
    Last Post: 11-21-2010, 09:48 AM
  3. Vacuum Pump
    By ranchak in forum Moldmaking
    Last Post: 10-26-2009, 01:13 PM
  4. OK, I've got my vacuum pump. Now what do I do with it?
    By DougO in forum Work Fixtures and Hold-Down Solutions
    Last Post: 07-09-2008, 03:35 AM
  5. Where to get a vacuum pump
    By whiteriver in forum DIY CNC Router Table Machines
    Last Post: 05-11-2004, 11:47 AM
