Hello all,
I am working with an older Busellato Super G system and the right hand router goves an error when you try to insert a bit. It accepts the bit and then immediately tells you to manually remove the bit. This happens with any bit/collar combination. The left router works perfectly.
Any ideas what would cause this?
Thanks in advance..
Mike
