Results 1 to 4 of 4
Thread: Need help with cutter diameter compensation
    Oct 2010
    Angry Need help with cutter diameter compensation
    I'm training on CNC mill and am currently writing programs in cutviewer and my cdc is not doing anything....Does anyone see what I am doing wrong?
    (STOCK/BLOCK,7.05,7.05,.5,1.525,1.525,.5)
    (COLOR,255,255,255)
    (TOOL/MILL,0.875,0,2,0)
    (COLOR,255,255,255)
    N10G0G90T1M6
    N20G54X-1Y-1S262M3
    N30G43H1Z.5
    N40G1Z-.6F2.096
    N50G41X0Y0D1
    N60X0Y3
    N70X.625Y4.24
    N80G2X2Y5R1.625
    N90G1X5Y5
    N100X5Y0
    N110X0Y0
    N120X-1Y-1
    N130G0Z5.
    N140M30
    Jul 2010
    Euskadi
    I´m not an expert but try the compensation movement from more than 2 times the ø of a tool. I mean, instead of : from X-1 Y-1 to X0 to Z0 try for example X-3 Y-1 the tool will have lenght to be compensated.
    Jun 2005
    us
    Did you put in your radius in the D offset ?
    You also need to cancel cutter comp g40 as you move away from finishing your part.
    Looks good to me.
    Tim
    Jan 2009
    Cutter Comp
    For good, safe programming, use decimal points in every dim. Example X-1 needs to be X-1. for a Fanuc style control. X-1 means -.0001 movement.
    X-1. means -1.000 movement. Always use a right angle move over 1/2 the cutter dia. to institute cutter comp and use a G40 to cancel it after doing a Z move to get the cutter above the part. Some controls don't like using the same number for Height offset and Cutter Comp. Try putting your cutter comp in offset register 11 and changing your program to read G1G41D11X0Y0. Don't get in the habit of using a Feed Rate of F2.096. Controls don't like that either. Use a Feed rate of 2. or 3. or whatever.
  1. Cutter compensation..
    By driftmaster in forum Mastercam
    Last Post: 04-03-2010, 03:14 PM
  2. cutter compensation
    By functionbikes in forum Tormach Personal CNC Mill
    Last Post: 06-17-2008, 03:39 AM
  3. .dxf to g-code converted with tool-diameter compensation?
    By cnczoner in forum General CNC (Mill and Lathe) Control Software (NC)
    Last Post: 08-16-2007, 08:31 AM
  4. G40 G41 G42 cutter diameter compensation not working
    By klick0 in forum LinuxCNC (formerly EMC2)
    Last Post: 03-17-2006, 06:49 PM
  5. Any Info On Tool Diameter Compensation?
    By FLUTE HEAD in forum TurboCNC
    Last Post: 10-26-2004, 06:02 PM
