Results 1 to 2 of 2
Thread: Making a ball
    Apr 2010
    Making a ball
    Trying to make a 1.316 Diameter ball on a SL-30 Haas Lathe with a .375 round cutting insert. I want to make one single pass.
    Jul 2005
    A 0.375 radius is very big. If you start with 1-3/8" diameter round bar and try turning a 1.316" diameter hemisphere on the end it is likely you will get a lot of chatter. Trying to turn more than a hemisphere will almost certainly cause a lot of chatter.
  1. Need help: Identify ball screw/ ball nut
    By RickOmatic in forum General Metal Working Machines
    Last Post: 07-27-2012, 05:04 PM
  2. R/C making
    By MBG in forum CNCzone Club House
    Last Post: 02-15-2010, 10:55 AM
  3. Making A CNC
    By pbawesome in forum DIY CNC Router Table Machines
    Last Post: 02-09-2009, 05:12 AM
  4. jig making
    By DerHammer in forum General Metalwork Discussion
    Last Post: 11-19-2007, 12:29 AM
  5. Big Ball Screw & Ball Nut mistake.
    By Jack F in forum General Metal Working Machines
    Last Post: 04-28-2006, 11:53 PM
