Results 1 to 1 of 1
Thread: Variable Speed Pulley Repair
    Jan 2005
    I have an older Cincinnati Machining Center which uses variable shiv pulleys for spindle speed control.
    I need to remove the fixed pulley half on the motor shaft but can not figure how to release the shiv from the motor shaft. There is a bronze spline piece on the inside of the shiv which also is split but I can see no way to release it.
    There is also another shaft inside the bronze piece which can be loosened but not removed by turning a socket screw deep inside the shaft.
    Nothing I have tried which includes hammer puller on the loosened shaft (with this shaft tight or loose makes no difference), trying to drive the bronze piece deeper into it's internal spline, attempting to use the socket screw inside the shaft as a jack screw in both directions.
    Any of you out there know how this is constructed and could give me some ideas on how to remove the shiv? If someone had a cross section drawing they would be willing to share, we could probably go from there.
    Check the pictures. The close up is a little blurred but gives the idea.
    Thanks for any and all help,
    Claude
    Attached Thumbnails Attached Thumbnails Variable Speed Pulley Repair-img_1196.jpg   Variable Speed Pulley Repair-img_1197.jpg   Variable Speed Pulley Repair-img_1198.jpg
  1. New Machine Build- variable speed pulley system (variator)
    By acourtjester in forum General Metal Working Machines
    Last Post: 07-20-2009, 12:23 PM
  2. Help to repair my Variable Speed DC Controller
    By ngr1 in forum General Electronics Discussion
    Last Post: 03-31-2009, 07:28 PM
  3. Need Help!- Bridgeport 2J variable speed pulley
    By JMA in forum Bridgeport and Hardinge Mills
    Last Post: 03-10-2009, 09:44 PM
  4. Need Help!- SX3 high speed pulley ???
    By cjdavis618 in forum Benchtop Machines
    Last Post: 07-03-2008, 02:10 PM
  5. variable speed???
    By turmite in forum General Electronics Discussion
    Last Post: 03-27-2004, 02:26 PM
