Results 1 to 2 of 2
Thread: Weird problem with Brother tapping center
    Jun 2010
    united states
    Got a Weird problem. Have a Brother TC32A and suddenly while operator was running it just doesn't mill the parts one cycle, just barely grazes the gates on the part. Checked milling head height, made sure tool holder wasn't loose. Ballscrew on Z was changed 4 weeks ago, so also checked coupler. Everything is good. Toolchange looks dead on. Parts that I measure were out .4 on height, and dowel pin holes were out over 2 mm. Kinda wondering about Thermal compensation. I know where you can turn it off and on in the parameters, but whats the different type of systems for this function? All the other machines I've seen with thermal compensation here are with Macome switchs, basically really sensitive prox switches. Thanks for anyones help.
    Jan 2008
    Did you figure out your problem?
    I bet you were in Dry run mode.
    Brother control uses 'dry run' to off set your coordinate set 'Z' value when pressed. You can change the value.
    Paul
  1. Brother TC-211 CNC Drill Tap Center
    By chakrind in forum General Metalwork Discussion
    Last Post: 09-22-2008, 04:47 PM
  2. Need Help!- Brother TC-217 CRT Problem
    By beaver in forum General CNC (Mill and Lathe) Control Software (NC)
    Last Post: 06-29-2008, 09:39 PM
  3. i've got a weird problem
    By fast89 in forum General Electronics Discussion
    Last Post: 12-19-2007, 03:31 AM
  4. Having weird problem
    By rustamd in forum LazyCam
    Last Post: 11-23-2007, 06:58 PM
  5. brother TC-20A CNC Tapping center
    By louis14 in forum General CNC (Mill and Lathe) Control Software (NC)
    Last Post: 08-07-2006, 07:29 PM
