Page 1 of 2 12 LastLast
Results 1 to 12 of 13
Thread: I lost parameter biesse rover 316
    Jun 2010
    Lithuania
    I lost mashine parameter biesse rover 316 could anyone help me?
    Feb 2008
    uk
    biesse memory back up battery
    firstly find out why?
    is the memory backup battery dead? see picture attatched.
    is the control a 480/481?
    anyone else that has an old biesse: these are getting old now. change the battery before you lose the memory too
    (put the new battery on in parallel first, before removing old battery. that way you wont lose memory while changing it!)
    its located on inside of controller frame.
    use long wires like the original so when corosion starts it has a long way to go before getting to the circuit boards. (dreaded blackwire corrosion is a killer of chips)
    Attached Thumbnails Attached Thumbnails I lost parameter biesse rover 316-biessebattery2.jpg
    so much to learn, so much to pass on.
    Jun 2010
    Lithuania
    Where that battery is? But with battery every think is ok i think. I lost parameters because machine stooped work. And i reinstall program from floppy.
    I do not know is every parameters are correct now.
    Now when i want to start bore program i got felt i0101 that meaning: Routine bzw. Festzyklus fehlt
    Feb 2008
    uk
    io101 is wrong tool config
    is your program calling head config 1 but machine is set to 2 etc?
    hc1 or hc2 etc
    all drills must be set up correctly in config.
    you must also call a tool change for the first part of a program otherwise machine doesnt know what tool its to use.
    Jun 2010
    Lithuania
    optimization program generating machine code and selecting tools his own discretion. maybe optimization program selecting wrong tools. i dont know. i will try to select different tool without optimization.
    Jun 2010
    Lithuania
    I change tool but I got same error.
    I'm trying to configure tools but I do not know how exactly to configure. I found list config 1, config 2 ant etc. and optimization 1, 2 etc i trying various configuration but machine do not work.
    Maybe you can help to config drills correctly?
    Jun 2010
    Lithuania
    I lost machine parameter biesse rover 316 NC 481 controller could anyone help me?
    I lost machine parameter biesse rover 316 NC 481 controller after battery crashed and unsuccessful reinstalling. Maybe anyone have boot disk with all data?
    Feb 2008
    uk
    do you have machine control manual?
    it shows how to configure tools
    did you contact biesse uk?
    Jun 2010
    Lithuania
    yes i have manual.
    i contacted with biesse uk they suggested nearly subsidiary.
    they sent parameter disk. i will try it when i replace new battery. with old battery program not working.
    Jan 2007
    Croatia
    Hy !!!
    I have same problem with Rover 322 (CNI 481 controller) !!!
    But i lost everything,C and D(eeprom) its empty.......first window when maschine start its disappeared (first window where its global zeroing button,coordinates......)
    sory for bad english !!!
    Can anyone help me please ???
    Jun 2010
    Lithuania
    hi, maybe i could help you. maybe you have skype? i have parameter disk for rover 316 mybe it will fit to rover22
    Quote Originally Posted by senna6666 View Post
    Hy !!!
    Feb 2008
    uk
    mar 404
    did you get yours up and running ok ? where did you get parameter disk from? uk or other?
  • Page 1 of 2 12 LastLast
    1. 3D en Biesse Rover A 3.30
      By larten in forum Spanish CNCzone
      Last Post: 11-05-2012, 10:01 PM
    2. Need Help!- Biesse rover
      By eng_semsem1980 in forum Commercial CNC Wood Routers
      Last Post: 12-13-2010, 07:16 AM
    3. Need Help!- I lost parameter rover 322
      By DANMI38 in forum CNC Machining Centers
      Last Post: 06-30-2010, 06:03 PM
    4. need help rover biesse 24
      By neon_x in forum CNC Machining Centers
      Last Post: 12-05-2009, 02:22 PM
    5. Biesse Rover 22
      By paul sharpe in forum Teachers Hang out
      Last Post: 10-09-2007, 01:50 PM
