You work with weeke bp10 ?
Evening all.
Have just aquired a Weeke BP10 with Num 750 control, has any one got an operating / programing manual for this machine please?
Somerset cnc
Hi.
Which software do you have/use to program your BP10 ?
Depending on this information we can help you.
Ottmar Petry
camSol / Germany
I do not know much about software. Where can look which software is installed? Controller NUM750b
I have problem with starting machine. I can move axis but cant start reference.
i put some pictures there Weeke BP 10 NUM750
2.jpg picture by mar404 - Photobucket
3.jpg picture by mar404 - Photobucket
maybe anyone can help? reference is not starting. maybe first of all need load some program and after start reference?
Somewhere, in the many boxes in my garage, I have copies of the manual that we had for our BP10. The problem is that I don't know which box it is in. How much detail are you looking for in a manual? I didn't find much helpful information in the book. One note in the book was that "the buttons symbols are standard (or typical) for this type of machine". I didn't know what half of them did, but was able to program for 3 1/2 years. Please let me know and I will try to find the correct box.
If you have the serial cable plugged into the board, it can be connected to a PC that can run a DOS window. Programming can then be done with PCnum, and the programs can then be loaded to the machine.
I have manual for BP10 but only in German language. But I can explain how to use this machine if you have skype.
I have a cnc Week 05 with 750 num kja control works nicely but when I send the G DNC machine and press start putujuje the specified codes, but does not include processing engine and when you put the M3 has provided an example of G code that would do this when the number način.Ali I put the program in the sub-dialog (starting position tiller) then do what you should write to the beginning of my code to include frezmotor
thank you
I have a problem my num 750 will accept the program with DNC communications when I try that after the information he then burst signal on the "?" gave some to them, and setup data
