Is the machine equipped with a pallet changer or rotary C axis? If so check to make sure the machine sees that they are clamped. If they are and you can't move axis by handwheel try it in MDI.
Hello:
I want to know if anybody has experience on Hitachi Seiki with Fanuc 11M. After a electric variation problems in the floor, I can just sent to Home the Z axe, but I can not send to Home or move the X and Y axis.
Thanks in advance
I'll assume that no alarms are present. Open the cabinent and see if the servoamps are powered up for the x and y axis. Are the machine positions close to the end of travel?
I would suggest looking at your ladder logic and find the axis interlock rung. If I remember correctly it is G300.1 for X axis and backtrack on the ladder to see what is inhibiting your table from moving.
Pl perss spindle stop button and move the x and y in jog mode if it move ur x,and y is in interlock condition pl check in details and resolve.All the best
cncrepairs
hi thepfy,
what credentials? are you talking about on the tools menu then scripting? If not can you tell me what it is?
